Go to Post Watch out, guys, Lisa's coming.... worse than any hurricane or tornado you can imagine! - KathieK [more]
Unread 20-02-2008, 13:52
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: pic: 1902 2008 Bot as Shipped.
2008 Specs
Weight: 119.7 Lbs
Functions: Hurdle( I guess that means herd to ), Cap, Lap, Effective Hybrid
Method: Can hurdle forwards and backwards, also cap and knock without touching the ball on the other side. See below for hybrid.
Finish: Powder Coated Neon Green and Safety orange for obnoxious awesomeness.
Drive:
6 Wheel Drive: 2 AM performance, 4 kit wheels, single plain drive.
2 Speed Frame Integrated Am Shifter: 14-15fps, 6-8Fps.
Fast and maneuverable.
Arm:
2" Bore 12" Stroke Piston running at 60psi working pressure for bottom axis, with variable positions if it needs to be changed during competition.
Elbow Joint is driven by a 256:1 AM Planetary Gearbox from the fp, with a further 3:1 sprocket reduction.
Elbow joint Moves at ~30 degrees per second allowing for quick hurdles and caps.
100 Click Encoder for Position Feedback in both autonomous and presets for arm in Operator Control.
2 75 lbs Gas struts to provide for absolutely no back drive on the arm with ball stowed, Motors work to position the arm both up and down.
Manipulator:
Banebot 64:1 on 3:1 reduction for intake wheels.
Intake wheels are 2008 kit wheels covered with High Traction Roughtop tread.
"Tusks" 1/8" Aluminum with schedule 40 all thread and tapped aluminum round bar to keep it in compression.
Tusks Forced closed by a 35lbs gas strut with two linear springs compressed around their shaft to create a constant pressure of 35 lbs + k*x of the linear springs.
Hybrid:
Autonomous sub routines set by location of the ball sent in by the robocoach via the IR.
Encoders inline with drive train and combined with a gyro using a PID controller for a field positioning system. I've been told tracking at +/- 3 inches tho not verified.
Sonar Sensors for collision "preparedness" and wall adjustments.
Consistently scored 20 points in autonomous and can hit all three balls based on the robocoachs input.
Comments on the video: I've been asked why we can't cap, We can, its actually much easier than hurdling, but just didn't show it because we were only filming and practicing hurdling. The video was filmed on a dead battery so its a bit slow ( 14-15 fps sucks battery fast on a 6wd ) and we only had about 15 minutes of drive time or so.
Improvements: Drivers need lots of practice, we finished a bit later than usual this year. Hybrid needs to be finalized and hopefully begin knocking the other ball off more consistently.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Team 1741 2008 bot video cgredalertcc Robot Showcase 6 28-02-2008 18:46
973 Completed Bot 2008 - ARMageddon pyxelz Robot Showcase 9 20-02-2008 20:05
pic: Team 1902- Exploding Bacon 2008 Robot Matt_Kaplan1902 Extra Discussion 33 11-02-2008 13:32
simulator (now that the bot is shipped) mcktim Programming 8 08-03-2006 18:45
pic: 2 Robots shipped.... CD47-Bot Robot Showcase 13 04-03-2003 02:43
