Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 17-02-2008, 18:01
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
pic: lift setup
Unread 17-02-2008, 18:03
thatmorman's Avatar
thatmorman thatmorman is offline
David
AKA: David
FRC #1510 (Wildcats)
thatmorman will become famous soon enough
Send a message via AIM to thatmorman Send a message via MSN to thatmorman
Re: pic: lift setup
how did you manage to gear down the cims? we used a van door, but it is extremely slow...
David Cobbley
Captain & Mechanical Leader
Team 1510
I <3 inventor & anyone in FIRST
Unread 17-02-2008, 18:51
Re: pic: lift setup
the shiny metal box is really a gearbox. just bought some gears (forget the number of teeth on each) but it raises it safely (with a pwm) in less 4 seconds consistently and after afew hours of precise machining on a very old crappy mill it works fine. the hardest part was just figuring out how to drive the lift up AND down.
Unread 17-02-2008, 21:44
Jaybee1405
Re: pic: lift setup
looks almost like an Aim High setup
cool though
Unread 20-02-2008, 03:18
thatmorman's Avatar
David
AKA: David
Re: pic: lift setup
yea its pretty kewl, do you think sometime you could find the gear ratio because just guessing i thought that would have to be a gear up of like 50 to 1, we used a van door and orrigionally had a two to one ratio, but that turned out to be not very effective so we changed it to one to one and it takes about 8 seconds to get to the top, very slow... thanks
David Cobbley
Team 1510
Unread 20-02-2008, 07:53
Re: pic: lift setup
bleh, numbers haha. i know its a 16 from the CIM to a 84 on a driveshaft connected to the driven pulley of a 32 that runs the belts.
it raises to about 120-ish inches in about 2 seconds under load
Unread 20-02-2008, 08:09
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Re: pic: lift setup
Looks nice. Does your arm and ball combination weigh 30~35 lbs all together?
If so, with the right gearing and decent bearings on your arm, my calculations tell me you should only need one CIM motor. (A cim motor puts out about 245.5Wo at the shaft at 40A). To lift a 30lb weight in 2 seconds, you should need about 204W mechanical.
Shiniest gearbox i've ever seen. Looks great. Got any video of it running? 120" is a long way!
-q
p.s. What's the window motor for?
Electrical Engineer Illini
Unread 20-02-2008, 16:02
Re: pic: lift setup
video coming soon.
it originally had only one cim on it, but it was deff straining a bit. the 8020 stock added alot of weight and i supersized some of the forklift/mounting peices.
another team member and i had 7 different forklift prototypes before choosing the final. the flex points are right where they should be, as is the very ridgid, beefy areas.
plus, we are only 90ish pounds so we figured what the heck, an extra cim wont hurt it.
the window motor shown is so we can raise and lower the forks anytime. this is for safety during the match, and adds a third way to grasp the ball.
Unread 20-02-2008, 19:13
Re: pic: lift setup
http://video.google.com/videoplay?do...83199508&hl=en
the last stage, or few feet of movement, is not at full power. this was one of the first test runs and i wanted to baby it near the top. also, the baby-ing was done above the height needed to hurdle. the lift extends to 40 inches above the top of the rack.
Scissort Lift vs. Crane vs. 4-Bar Lift vs. Gas Springs AdamC Technical Discussion 31 20-01-2008 18:49
pic: Tempest 'N Tampa Field Setup Stephen Kowski Extra Discussion 2 30-09-2007 22:03
pic: 1261's GuitarHero/Xbox control setup Adamskiy Extra Discussion 13 20-03-2007 12:22
pic: Brazilian Invitational field setup Manoel Extra Discussion 4 16-05-2005 14:01
