Go to Post I was hoping they'd be selling robots. - Tristan Lall [more]
Unread 21-02-2008, 08:52
aviad1942's Avatar
aviad1942 aviad1942 is offline
FRC #1942 (Cinderella)
aviad1942 will become famous soon enough
Send a message via ICQ to aviad1942 Send a message via Yahoo to aviad1942
pic: electrical panel- team 1942 Cinderella
Unread 21-02-2008, 08:53
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: pic: electrical panel- team 1942 Cinderella
Is this your competition board?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 21-02-2008, 09:19
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
While it looks gorgeous, I'd hate to be the inspector who has to make sure the wiring is correct.
Unread 21-02-2008, 09:23
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I'm no electrical expert but I believe the main breaker has to be connected to the distribution block and then the maxi block and breaker panels.
Unread 21-02-2008, 09:29
Mentor,QCR Planning
Thats why I asked if it was his competition panel. You are correct. THe main breaker must be connected the distribution block, and then all breaker panel feeds originate from the distribution block.
Unread 21-02-2008, 10:42
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
I agree, the Robot Electrical Distribution Diagram is the definitive picture that follows the electrical rules. Please see R50 first sentence...
"The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit
breaker distribution panels shall be connected as shown in the 2008 Power Distribution Diagram."
The Main Breaker must feed the Rockwell block which in turn will feed any breaker panels you decide to use. The GDC has also rules that you may remove unused sections of the Rockwell block and cut the yellow jumpers to size as needed for your design. Actually, I like this layout. It might make it a little harder to replace a component but you have to admit it looks pretty.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-02-2008, 10:45
Mentor,QCR Planning
Diagram.
Yes, it is a great design. No wire clutter to deal with. I was thinking the same thing, would be hard to replace a wire if you needed to.
On a side note, Al, could you PM the part numbers of the pins, conncetor, and cable spool you use for making your PWM cables.
Thanks.
Unread 21-02-2008, 12:29
RoXmySoX's Avatar
RoXmySoX RoXmySoX is offline
AKA: Cristina M. (Beaner)
FRC #2582 (PantherBots)
Team Role: Electrical
RoXmySoX will become famous soon enough
Send a message via Yahoo to RoXmySoX
It looks awesome guys great job. It might bring up questions during the competition due to the fact that some of your wiring might be wired wrong. I would check up on it.
GO PANTHERBOTS! CLASS OF 08'
2008 Rookie Inspiration Award-Lone Star Regional
Unread 21-02-2008, 12:51
Whisper's Avatar
Whisper Whisper is offline
The Seventh Geist of Echo Squad
AKA: Tammo
FRC #1091 (Oriole Assult)
Whisper is on a distinguished road
yall shoulda used a different color. White's pretty plain.
Anyways, is the other side of the board covered? cuse if its not, then the wiring would be pretty easy to check. And if it is, i would most definitely suggest taking off the cover. It will be almost impossible to replace a part if something goes wrong. Which, since it is Virtually impossible to replace, It is Impossibly probable that something will break.
I refuse to answer that question on the grounds that i dont know the answer.
Unread 21-02-2008, 15:31
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
very very very very nice
Unread 21-02-2008, 15:49
aviad1942's Avatar
we closed the back side of the board- for safety ! but all the board can be removed easily, when something goes wrong!
then is not a problem to check or replace something !
2007 Israel Regional
Kleiner Perkins Caufield & Byers Entrepreneurship Award
2006 Israel Regional
Xerox Creativity Award & Rookie All Star Award
Semifinalists
http://www.youtube.com/profile_video...=aviad1942&p=r
http://www.flickr.com/photos/7152842@N06/
pic: Team 1942- Israel Regional 2007 aviad1942 Extra Discussion 2 20-10-2007 10:28
pic: Our Electrical Panel AndyB Extra Discussion 3 18-05-2007 08:49
pic: Team 1717 Panel (alone) rsilverstein Extra Discussion 13 28-03-2007 16:06
pic: Team 1717 Panel rsilverstein Extra Discussion 3 27-03-2007 15:55
pic: Team 810's Robot - Front Panel LetsGo810 Extra Discussion 2 30-01-2007 10:31
