Go to Post Nothing you learn can truly prepare you for everything that comes your way. - sciguy125 [more]
Unread 21-02-2008, 17:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Re: pic: 1155 Finished Robot
Cool! I like how the garage track makes the gripper rotate more parallel to the floor as it gets down low.
When you say 'IR Sensor is used to direct the robot in Hybrid' do you mean an IR level sensor or that your robot takes commands from a remote?
Any videos of your autonomous? Have you all tried your autonomous with other remotes pointing around for real-life simulation?
Great use of steel. Many say it isn't possible. Apparently it is.
-q
Electrical Engineer Illini
pic: Finished robot image Andrew Schuetze Extra Discussion 29 18-02-2008 07:30
pic: Finished 2008 Robot!!! ZachKahn Extra Discussion 7 08-01-2008 19:58
pic: 832 Finished Robot firebelly Robot Showcase 5 23-02-2007 15:05
pic: 1493 Finished robot Dan-o Robot Showcase 10 24-02-2005 23:20
pic: Finished robot Matt_Kitts Robot Showcase 1 23-02-2005 11:49
