Re: pic: Team 34 - Differential
Very nice! Whats the part number for those spiral gears. Those look perfect for a differential project im working on.
(2) LSA110Y-R (Right Hand Spiral) (2) LSA110Y-L (Left Hand Spiral) Both are 18 tooth, 18 DP spiral bevel gears. |
Mr.Sparks as a fan of drive systems, I am quite impressed with what you have done here looks great. Will 34 be attending the Palmetto if so I will take a look at it there if not Championships for sure. Good luck this year.
-Drew |
should've taken it one step further with 4wd, then maybe 1 step past that with 4wd 4wheel steering
i wonder if anyone this year is upscaling and high performance rc car 4wd and full independent suspension, that would be awesome to watch drive. i love the limited slip differential |
Unfortunately, we will not be at Palmetto this year. We are attending Peachtree and Bayou.
How difficult would it have been to integrate the clutch plates into the diff housing, like in a normal automotive limited slip rearend? Seems like a lot of extra hardware there....
(when we were considering Ackermann steering, we were planning on using a software differential) |
| Differential? | Darunada | Technical Discussion | 27 | 13-01-2008 16:04 |
| pic: Differential Swerve (Close Up View) with Advanced Gear Kit | nonother | Extra Discussion | 8 | 16-05-2007 01:14 |
| pic: Differential Swerve (Bottom View) with Advanced Gear Kit | nonother | Extra Discussion | 0 | 14-05-2007 23:31 |
| VEX Differential | RoboticEngineer | Programming | 8 | 23-02-2006 00:40 |
