Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Unread 26-02-2008, 14:41
GaryVoshol's Avatar
Cogito ergo arbitro
Re: pic: Big Mouse 2
The lane divider bump shouldn't do a whole lot.
What's this about a bump under the overpass? Is there something I missed?
This is what you evidently missed:
6.2.3 The LANE DIVIDER
The TRACK is divided by a LANE DIVIDER that extends along the major axis of the TRACK. The
LANE DIVIDER is six feet tall and approximately 27 feet long. It is constructed of 1-1/2 inch O.D.
steel pipe and connecting hardware, forming railing panels. The openings in the railing panels are
filled with clear plastic to prevent portions of ROBOTS from inadvertently passing through the
structure. The LANE DIVIDER is attached to vertical posts that are anchored to supporting plates
covered by carpet. Note that these plates will create a bump in the carpet approximately 1/2 inch
tall
, and as a result the surface of the TRACK will not be perfectly flat. ROBOTS must be designed
to accommodate these surface variations. The LANE DIVIDER is attached to the floor such that it
should remain vertical and not move when struck by ROBOTS.
(emphasis mine)
(since 2004)
Optical Mouse Navigation phrontist Programming 60 14-03-2005 21:48
Looking for Mouse part Mr. Lim Electrical 3 27-12-2004 19:56
Optical Mouse / Ball Mouse Clark Gilbert Chit-Chat 26 22-07-2004 13:17
Mouse Odometer charlie_grr Chit-Chat 5 11-12-2003 00:34
Mighty Mouse Is Here RebAl Robot Showcase 0 31-03-2002 21:55
