Originally Posted by GaryVoshol
This is what you evidently missed:
6.2.3 The LANE DIVIDER
The TRACK is divided by a LANE DIVIDER that extends along the major axis of the TRACK. The
LANE DIVIDER is six feet tall and approximately 27 feet long. It is constructed of 1-1/2 inch O.D.
steel pipe and connecting hardware, forming railing panels. The openings in the railing panels are
filled with clear plastic to prevent portions of ROBOTS from inadvertently passing through the
structure. The LANE DIVIDER is attached to vertical posts that are anchored to supporting plates
covered by carpet. Note that these plates will create a bump in the carpet approximately 1/2 inch
tall, and as a result the surface of the TRACK will not be perfectly flat. ROBOTS must be designed
to accommodate these surface variations. The LANE DIVIDER is attached to the floor such that it
should remain vertical and not move when struck by ROBOTS.
(emphasis mine)
Is that under the Overpass? No. It's under the Lane Divider, only part of which is under the Overpass. The reason I was asking what I'd missed is that there isn't a bump under the Overpass in the manual at all, other than the lane divider one, which shouldn't affect play very much, if at all. Tottanka is an FTA, so he'd know if there was a bump that wasn't called out and should have been.
I knew about the lane divider bumps already.
