Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 26-02-2008, 21:00
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
pic: Team Daytona (2152) Rack & Pinion Ackerman Steering
Unread 26-02-2008, 21:04
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Re: pic: Team Daytona (2152) Rack & Pinion Ackerman Steering
What is that circuit board precariously positioned near the outside? IR board?
Unread 26-02-2008, 21:07
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Is it a line sensor/light reflective sensor?
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 26-02-2008, 22:16
Engineering Mentor
AKA: Wally Ritchie
It's a perfboard that mounts the pot that acts as PID loop feedback sensor.
A steel pinion drives the steel rack. A plastic gear on the same shaft
drives a plastic gear attached to the potentiometer. The sensor gearing
matches most of the full range of the pot to the full range of the rack to
provide better resolution for the PID loop.
It's looks more fragile than it is. Its protective cover is removed in the
photo. Perfboard is unfortunately a bit ugly but still works well.
Unread 27-02-2008, 07:59
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Whats you weight? I see a lot of 80/20. That stuff is great, but very heavy.
Unread 27-02-2008, 10:45
Engineering Mentor
AKA: Wally Ritchie
We were are 98 lbs excluding bumpers and battery. We expect to come in
around 105 -110, well under the max.
1010 extrusions are relatively heavy at 0.51 lbs/linear foot. But they are unbeatable for strength, rigidity, and flexibility of the non-mechanical kind. We offset the frame weight by lots of lightening in areas where the main structural support comes from the frame.
pic: Team 34 - Ackerman Steering Ed Sparks Robot Showcase 15 27-02-2008 09:28
Team Daytona's (2152) Robot of Tomorrow writchie Robot Showcase 0 26-02-2008 17:48
Rack & Pinion SHS Blue Devils General Forum 5 12-01-2008 17:59
Rack and Pinon Steering macwhoo Technical Discussion 0 08-01-2008 20:39
rack and pinion. greencactus3 Pneumatics 17 04-11-2004 23:24
