pic: Team Daytona (2152) Rack & Pinion Ackerman Steering
Re: pic: Team Daytona (2152) Rack & Pinion Ackerman Steering
What is that circuit board precariously positioned near the outside? IR board?
Is it a line sensor/light reflective sensor?
A steel pinion drives the steel rack. A plastic gear on the same shaft drives a plastic gear attached to the potentiometer. The sensor gearing matches most of the full range of the pot to the full range of the rack to provide better resolution for the PID loop. It's looks more fragile than it is. Its protective cover is removed in the photo. Perfboard is unfortunately a bit ugly but still works well. |
Whats you weight? I see a lot of 80/20. That stuff is great, but very heavy.
around 105 -110, well under the max. 1010 extrusions are relatively heavy at 0.51 lbs/linear foot. But they are unbeatable for strength, rigidity, and flexibility of the non-mechanical kind. We offset the frame weight by lots of lightening in areas where the main structural support comes from the frame. |
| pic: Team 34 - Ackerman Steering | Ed Sparks | Robot Showcase | 15 | 27-02-2008 09:28 |
| Team Daytona's (2152) Robot of Tomorrow | writchie | Robot Showcase | 0 | 26-02-2008 17:48 |
| Rack & Pinion | SHS Blue Devils | General Forum | 5 | 12-01-2008 17:59 |
| Rack and Pinon Steering | macwhoo | Technical Discussion | 0 | 08-01-2008 20:39 |
| rack and pinion. | greencactus3 | Pneumatics | 17 | 04-11-2004 23:24 |
