Re: pic: Behold The Black Box
well be releasing the schematics and code(in the works with releasing it under GPL v2) some time after march( not that we want to keep it from teams but were all very busy with other things and don't really have time to get it all together until after LSR). the chip is a parallax propeller chip. and no it doesn't record any thing its more of an electrical / programing black box i.e. I don't care how it works or whats going on all I know Is I tell it this port is a ping sensor and it gives me a distance in inches.
and depending on how well things go this summer, you may be able to buy one(or more) of these for next season at the 50- 75ish price point(there may also be a drag and drop programing tool that develops the C code for the RC to run these things). Last edited by Stuart : 28-02-2008 at 16:18. |
This looks great, I do like the professional "naked" look of a board, but a nice black case for this would really be nice. (adds to the name too)
If you need drivers for an Memsic Accelerometer, I have written one before, I can dig it out if you want it. I <3 embedded systems! Last edited by Arkorobotics : 28-02-2008 at 16:30. Reason: I didn't read what processor it was.. :P |
One of our programmers was working on a "black box" last year, but he had a lot on his plate this year (i.e. control box with built in laptop w/ GUI), so he didn't get around to making one. We were just discussing something like that at the NJ regional earlier today, since we needed to know what our IR sensors were returning in autonomous.
Sooo.... tiDSP, Freescale, Atmel, Microchip, etc.?
aka, what processor is that? I don't understand what you mean by 'no decrease in update rate'. If you have more data comming over the same line, it will take longer for it to come through, unless you double you're baud rate each time you add another box. (double the data, double the rate = same time. double the data, same rate = double the time) Did you guys design the PCB? If not, where'd you get it from? -q |
the chip being used is a propeller chip by parallax. as far as how the protocol maintains its speed . . well I wont go in to much detail here( but I will later) I will say that if you took a token ring . . and made it a line you would have something that looks like a "black box array" as I call it.
Hi
I was attracted to this thread by it's title, but now I'm confused... A "Black-Box" is a datalogger, used to record what happens during flight (for later analysis), but what you are describing seems more of a serial I/O device... ie: there is no mention of data storage capacity. Is the purpose of this board to expand the RC's I/O capability, or is it truly an event logger. I needed a data logger this year, so I used a serial flash board from SparkFun to do the job simply. Here is the white paper: http://www.chiefdelphi.com/media/papers/2065 |
"Black box" is also a term for something that you don't need to know the inner workings of, just the interfaces. The classic example of this meaning of "black box" is a car - the average person doesn't know how it works, but they know how to use the interfaces (shifter, gas pedal (more correctly termed the air pedal though...), brake pedal, etc.) to achieve a desired result. This board takes a whole bunch of sensor inputs and presents the result of the signal processing to the RC in a nice series of packets without requiring that the RC programmer to know how it gets the data from the sensor, the data just comes in the serial port.
But.... the original poster said: Quote:
Phil. |
It looks like a sensor relay that expands the number of sensor inputs to the RC to me...
| pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled. | bubbablahmon | Extra Discussion | 15 | 22-01-2008 09:40 |
| Little Black Box | NOV8R | Electrical | 3 | 11-02-2007 00:04 |
| pic: Team 356 Black Box - Part 2b | CD47-Bot | Robot Showcase | 21 | 23-02-2004 07:41 |
| pic: Team 356's Little Black Box | CD47-Bot | Robot Showcase | 7 | 22-02-2004 23:13 |
| Black Gear Box | Jay05 | Motors | 4 | 04-04-2003 14:44 |
