Go to Post overly agressive play, sudden torque gains, and signs of robot acne will cause immediate suspicion, and may be used as justification for a complete tear-down inspection - dlavery [more]
  #31   Spotlight this post!
Unread 01-03-2008, 22:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Impeding in Hybrid
Originally Posted by T3_1565 View Post
See the problem with this argument it the fact that the refs have to assume things.. which they aren't going to do. You can't assume they are blocking on purpose, as was said (wrong place at the wrong time). and you can't assume that the speedy bots aren't trying to hit people (they only do laps cause they "miss" the opposing robots). So if you leave it up to assuming they you will get bad calls.
Better to make sure your robot doesn't travel a billion mile an hour around a corner or, like was said, in the opposing zone.
And as was said a billion mile an hour auto mode has never been allowed, why should it be now, whereas defensive autos have always been allowed.
Firstly, it was extremely evident to me that certain teams started off with automodes that traveled around the field, then they figured out that they weren't working that well, and that other teams were getting HUGE hybrid scores. At this point I noticed said teams abandoning their previous efforts, moving forward three feet, and stopping. Why else would you do this, when it goes against previously established behavior, unless you were trying to impede the opposing alliance?
Furthermore, a "billion mile an hour" automode has been allowed. Teams have had extremely fast autonomous modes in 2003 and 2004. I saw some extremely violent collisions in both years. I don't ever recall seeing a DQ or penalty for such.
Your point about defensive automodes always being allowed is kind of moot, as the Q&A referenced above clearly prohibits it this season.
If there's no way to determine intent with respect to blocking (and I think there very clearly is. It was 110% clear who was attempting to impede other alliances, and who was trying to run laps), then I think there's no logical way that you can penalize/yellow card/dq a team that happens to hit such a team who may or may not be impeding the track intentionally.
If you penalize the team trying to navigate the field, then the impeding robot has scored a double victory--they have avoided a yellow card that I believe they certainly deserve, and they have given their opponent a penalty/yellow/red card. How is this fair?
I think a yellow card is a totally justifiable penalty. With teams like MWR had, two good hybrid bots on one alliance can score between 24-32 points in lines, and 8-16 points in balls, plus whatever the third robot can do. With teams impeding at the far lane divider, the most these 2 teams can score is 16 points in lines and 8-16 points in balls. Even if the offending team were assessed a 10 point penalty, they have effectively negated up to 24-32 points for the other alliance. Without the yellow card, it would be totally worth it for everyone who did not have a great hybrid mode to just camp at the corner and take 10 point penalties all day, to keep more than 10 points from being scored against them.
I agree a verbal warning would of been good, instead of right to the yellow card
To be fair to the referees, us armchair quarterbacks have no idea whether 1114 was or was not given such a warning prior to being carded.
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 01-03-2008, 22:32
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Originally Posted by Laxphan1525 View Post
the refs weren't calling the impeding traffic award.
Dang I want that award =D
From the webcasts, I didnt see this being called either.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
  #33   Spotlight this post!
Unread 01-03-2008, 22:40
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Remember that per <G40>:
Note that a ROBOT is not IMPEDING traffic if:
• there is a clear “passing lane” around the ROBOT.
If all three teams drove out and stopped right next to each other, that might be a violation. Otherwise, it seems like fair defense to me.
On the whole, I don't like the idea of being penalized for what happens in autonomous mode. There are so many things that can go wrong, and the only way to stop the robot is to E-stop - which disables the robot for the rest of the match. Perhaps there should be an autonomous-only E-stop.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
  #34   Spotlight this post!
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
After thinking about this problem for a while I think MWR refs actually did a pretty good job. One of the things that I think is most important in a ref crew is consistancy, basically, dont call a penalty on 1 team and not call it when another team does the same thing. The MWR called the penalty on the robot moving, and not on the team impeding. I dont think this was the right call, however after the first incident, all teams knew the risks of autonomous mode. I would have liked to see it called the other way, however they took over a problem that wasnt braught up before and remained consistant with it. I dont think the yellow card had a large impact on 1114, however I may be wrong.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
  #35   Spotlight this post!
Unread 01-03-2008, 22:43
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
If you didn't see this penalty being called, it is likely that either the blocked team had not bumped to pass, there was a clear lane around the impeding bot, one of the impeding bots was from the same alliance as the robot being impeded, the impeding robot was in the process of hurdling, or the impeding action didn't last for more than six seconds. Many impeding counts were started. Not many penalties were called. Please read <G40> and <G41> to understand how this rule actually works.
2007 Pittsburgh Website Award
Team 1388 - Eagle Robotics
_
  #36   Spotlight this post!
Unread 01-03-2008, 22:44
SU 39 SU 39 is offline
AKA: Andrew Su
FRC #0846 (Funky Monkeys)
SU 39 will become famous soon enoughSU 39 will become famous soon enough
That's what your IR board is for.
  #37   Spotlight this post!
Unread 01-03-2008, 22:45
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
That was the first time they hit someone that hard (I believe anyways) so no they weren't warned.
Secondly, I don't think ethier should get a yellow card simply cause you can't penalize a robot that doesn't move. A lap bot takes a wide turn and crashes into a robot without an auto mode and that bot gets a yellow card for impeding?? Is that fair??
Ethier way no yellow cards should be awarded, not right away anyways.
It was a little unfair, but when 1114 got a yellow card, they didn't hit a "drive 3 feet and stop" bot, they hit a bot who had crossed one line. So I believe a warning would of worked.. but I'm not a ref.
It comes down to what people assume, and unfortunatly that changes from person to person, and bad calls will always be called, and some people won't think they are bad calls, and some people will.
  #38   Spotlight this post!
Unread 01-03-2008, 22:46
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
As soon as the robot makes a turn, your IR board becomes somewhat useless.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
  #39   Spotlight this post!
Unread 01-03-2008, 22:48
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
If you weren't on the field, you would have no way of knowing whether a team received a warning.
_
  #40   Spotlight this post!
Unread 01-03-2008, 22:52
AKA: Joey
The rule is for intentional impeding. If a robot has never had an autonomous mode, I think it is safe to assume they arent doing it intentionally.
Joey
  #41   Spotlight this post!
Unread 01-03-2008, 22:58
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
There's no crying in robotics!
  #42   Spotlight this post!
Unread 01-03-2008, 23:06
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I think it sucks. You aren't allowed to intentionally impede anyone during teleoperated mode, so why should you be able to in hybrid?
What if you arent "intentionally" impeding? sure if you have an auto mode that drives forward 3 feet and stops, its impeding, but so could an auto that hits the middle wall and breaks. A rule preventing impeding during hybrid would be very subjective considering the large potential for error.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
  #43   Spotlight this post!
Unread 01-03-2008, 23:12
Cory's Avatar
AKA: Cory McBride
I really think it's pretty obvious who has an auto mode that does something, and goes wrong, and who has an auto mode that's sole purpose is to impede other robots.
In the above situation, you could easily tell by assessing whether it stopped short of the divider, hits the divider and keeps spinning it's wheels, starts madly spinning in circles, etc.
-To anyone playing devil's advocate, an impeding team could certainly have their robot do the above things to mimic a hybrid mode gone bad, but seeing as impeding teams is already illegal, I should hope nobody would stoop to such lows.
2001-2004: Team 100
  #44   Spotlight this post!
Unread 01-03-2008, 23:25
Vogel648 Vogel648 is offline
Student Programming Leader
FRC #0648 (QC Elite)
Team Role: Student
Vogel648 is on a distinguished road
As the robocoach of one of the teams(along with 16, bombsquad), who impeded 1114 and 1024's hybrid mode in the semi-final matches of Chicago, I would like to say, that there was concern about the legality of the strategy. We specifically asked the refs if that would be called a penalty.
Saying that a low numbered team(team 16 bombsquad) should have known better is ridiculous. The rules allowed it and it did not cause any excess risk of damage to robots or humans.
Honestly I would be fine seeing this change over to a penalty, but don't rip on us for playing with some strategy.
  #45   Spotlight this post!
Unread 01-03-2008, 23:26
Just so we are clear on what we mean by 3 feet and stop, look at what 48/16 did to 1114 in quals/elims.
They were probably under the influence it was a legal move, as this is a grayish area in the minds of most.
I believe it should be illegal, because of the Q&A ruling that states it is. However, it seemed liked very few people knew about it.
And, this argument isn't even for our own benefit; 973 has yet to run a hybrid mode on our competition bot. We have some decent modes for past robots (so were not all that behind).
G22 Direction of Traffic Hilarity Kevin Sevcik Rules/Strategy 16 17-01-2008 22:30
Intentionally tipping and disabling your own robot FTW... Mr. Lim Rules/Strategy 30 14-01-2008 13:35
Traffic and Weather? indieFan Championship Event 7 30-01-2007 15:30
Week 2 Regional Traffic Jam Koko Ed Regional Competitions 6 07-03-2006 22:11
Site Traffic Chart archiver 2000 2 23-06-2002 22:01
