Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 02-03-2008, 03:39
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Re: pic: Behold The Black Box
Sooo.... tiDSP, Freescale, Atmel, Microchip, etc.?
aka, what processor is that?
I don't understand what you mean by 'no decrease in update rate'. If you have more data comming over the same line, it will take longer for it to come through, unless you double you're baud rate each time you add another box. (double the data, double the rate = same time. double the data, same rate = double the time)
Did you guys design the PCB? If not, where'd you get it from?
-q
Electrical Engineer Illini
Unread 19-03-2008, 01:43
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
the chip being used is a propeller chip by parallax. as far as how the protocol maintains its speed . . well I wont go in to much detail here( but I will later) I will say that if you took a token ring . . and made it a line you would have something that looks like a "black box array" as I call it.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 19-03-2008, 08:39
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Hi
I was attracted to this thread by it's title, but now I'm confused...
A "Black-Box" is a datalogger, used to record what happens during flight (for later analysis), but what you are describing seems more of a serial I/O device... ie: there is no mention of data storage capacity.
Is the purpose of this board to expand the RC's I/O capability, or is it truly an event logger.
I needed a data logger this year, so I used a serial flash board from SparkFun to do the job simply. Here is the white paper: http://www.chiefdelphi.com/media/papers/2065
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 19-03-2008, 17:40
in between teams
AKA: Luke Van Oort
"Black box" is also a term for something that you don't need to know the inner workings of, just the interfaces. The classic example of this meaning of "black box" is a car - the average person doesn't know how it works, but they know how to use the interfaces (shifter, gas pedal (more correctly termed the air pedal though...), brake pedal, etc.) to achieve a desired result. This board takes a whole bunch of sensor inputs and presents the result of the signal processing to the RC in a nice series of packets without requiring that the RC programmer to know how it gets the data from the sensor, the data just comes in the serial port.
Team 1219: 2009 - Mentor
Unread 19-03-2008, 21:50
PhilBot's Avatar
AKA: Phil Malone
OK, I get that... ie: the company called "Black Box" that makes a million different I/O devices.
But.... the original poster said:
its called the Black Box after the black box found in airplanes
So I wondered if it really WAS a data recorder "like in an airplane".
Phil.
Phil Malone
Unread 20-03-2008, 09:21
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
It looks like a sensor relay that expands the number of sensor inputs to the RC to me...
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled. bubbablahmon Extra Discussion 15 22-01-2008 09:40
Little Black Box NOV8R Electrical 3 11-02-2007 00:04
pic: Team 356 Black Box - Part 2b CD47-Bot Robot Showcase 21 23-02-2004 07:41
pic: Team 356's Little Black Box CD47-Bot Robot Showcase 7 22-02-2004 23:13
Black Gear Box Jay05 Motors 4 04-04-2003 14:44
