Go to Post I have a feeling that we're about to deprive the world of Poof balls for a while. - DCA Fan [more]
Unread 27-02-2008, 11:09
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: When Did You Finish Your Robot
We were mechanically finished a day or two before shipped.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 27-02-2008, 11:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Our robot will be finished after IRI.
But seriously
This is the first year that I have been on the team that we have shipped a robot that does every function well and doesn't need major work on Thursday. I am really pleased with the team this year.
Some auton work and a little tweaking and we are good-to-go with a minor weight problem
Unread 27-02-2008, 11:31
DayZiro DayZiro is offline
FRC #2518
DayZiro is an unknown quantity at this point
We had our robot controlled by the joysticks after only two weeks of getting it, not bad for a first-year team. We were able to spend the next 4 weeks adding a lifting arm, testing out a front U-shaped arm, rewriring, and changing the code.
We had something that we were proud of by Feb. 16 so we could test it out in a skirmish we held against some other local teams.
Unread 27-02-2008, 13:34
boonski's Avatar
boonski boonski is offline
Knight of Alloy
AKA: Matt Taylor
FRC #1535 (Knights of Alloy)
Team Role: Scout
boonski will become famous soon enoughboonski will become famous soon enough
Send a message via MSN to boonski Send a message via Yahoo to boonski
Team 1535's robot was finished but after we weighed Sir Jimmy (our robot), he was 4 lbs overweight... SO we are but we are not finished at the same time? If that makes any sense...
ATTENDING:
Waterloo Regional 2008
The Knights Of Alloy 1535!
Formally Known as the 1596 International Instigators
Unread 03-03-2008, 09:14
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
finished is a a very interpretable term. My team was able to ship a working machine that only needs a few things to get replaced ( there was a bad solenoid) , but is the robot really ever done? Like hey, lets try this program , or hey lets try this gear.
I belive that the robot is never done that it just evolves less rapidly
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 04-03-2008, 07:20
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Agreed. There is always room for improvements!
Unread 04-03-2008, 07:28
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
finish....?!?!?!?!?!?:
hahaha....you're funny....
but when one thinks about it....is a robot ever finished?
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 04-03-2008, 07:42
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Finishing... that's funny.
Sometime between championships and IRI =D
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 04-03-2008, 08:46
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
I predict it will be finished about 5 minutes before our 1st match on Friday, March 14. Actually "finished" might not be accurate, more like, "we aborted the remainder of the planned features". Yea, that's it.
Ed Sparks
MECH TECH FRC-3959
Unread 04-03-2008, 15:45
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
8pm on the day before ship day.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 04-03-2008, 17:29
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
HA, who needs a finished robot when you can have all the fun of building one at regionals... anybody? 1 hour befor ship our launcher team shows up and says, "It doesn't work, throw the phnematics in and we will build it there." Doesn't that sound like fun...
Unread 04-03-2008, 17:41
dtengineering's Avatar
dtengineering dtengineering is online now
AKA: Jason Brett
Well, we THOUGHT we had finished our 2005 robot after the 2005 GTR. But it turned out it was a great practice drivebase for testing this year's drive code, so off came the arm, and on went a gyro and new code.
We THOUGHT we had finished our 2006 robot after the 2006 GTR. But it turned out that we needed a couple CIMs from it for this year's machine. So off came the gearboxes and CIMs then back on they went, minus two of the CIMs that we use to race around the track this year.
We THOUGHT we had finished our 2007 robot after the 2007 GTR, but it turned out that a nearby team wanted to borrow some pneumatics from it and we needed to re-use some of the sonar sensors, so off they came.
We THOUGHT we had finished building our 2008 robot when we put it in the shipping crate... but snapped the "hockey sticks" in about five minutes at Portland, and are now re-designing our gripper mechanism to work even better, and will be changing a few sensors as well when we get to Seattle.
I would, however, say that we have finally, truly, finished with our 2004 robot. After pulling the electronics several years ago, the motors last year, and the scissors lift (to use as a test to see if we wanted to scissors the ball over the overpass) this year... there just isn't that much left. So that would suggest that we typically finish a robot about five years after we start it.
Jason
Unread 10-03-2008, 22:39
GeneralJB's Avatar
GeneralJB GeneralJB is offline
AKA: Hamez
FRC #1793 (The Pilots)
GeneralJB is an unknown quantity at this point
we were pretty lucky this year, we finished a few days ahead of schedule, only to realize that front-wheel drive wans't gonna cut it. View evidence file #1
yeah. it seems omni-wheels dont like 80 lbs focused on them alone. we swapped EVERYTHING and finished within a day and a half. just in time for shipping.
P.S., the robots nickname this year is Abrams, because it has a massive barrel on the front, and we never had to fix anything after matches. our most reliable in years!
Unread 11-03-2008, 09:33
Danielle H's Avatar
Danielle H Danielle H is offline
"Safety Captain... WHAT?!?!"
AKA: Danni Hurley
FRC #0393 (Full Metal Jackets)
Team Role: Communications
Danielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant futureDanielle H has a brilliant future
Send a message via AIM to Danielle H
We were driving it at 8:30pm the night before ship, but that doesn't mean we were done. One of our mentors was going to come in during school the next day and tweak some programming problems, and a couple other students were in the shop until about 1:30am to finish the first coat of paint. And when I got there an hour before shipping, things were still being looked at, put together and changed.
But, I got home at 11:30pm-11:45pm the day before ship date, which is the first time in the 3 years I've been on the team that I've come home before 2-3am.
It was kinda nice.
But I felt bad that I couldn't stay and paint.
^Don't be afraid to be honest with me... you might make my day!
"If you think it's right, do it again."
2008 Palmetto Regional Finalists
THANKS 342, 343, and 804!
Attending:Kokomo Kick-Off, Boilermaker Regional, Palmetto Regional
SHIP DAY IS HERE!!! Did you finish??? sgsdragons General Forum 50 19-02-2008 11:52
When did you finish your robot? (if at all :) Leav General Forum 34 16-02-2006 13:21
When did you get your kit? NextPerception Kit & Additional Hardware 3 18-01-2006 21:12
When Did You Have Your First Accident? Dorienne Chit-Chat 44 17-11-2004 21:32
Where did you build your robot? Summmergrl2298 Chit-Chat 25 13-04-2002 15:30
