Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
Unread 05-03-2008, 14:20
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: pic: Beachbot 2008
Originally Posted by ShaneP View Post
Forwards: Poke with arm.
or
Backwards: Pop them out from underneath.
And how good/fast does he do it?
What is your hybrid plan?
BTW, i liked your speed racer
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 05-03-2008, 14:25
ShaneP's Avatar
ShaneP ShaneP is offline
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Haha, thanks.
Pops it off pretty quick, and is fairly consistent. Hybrid: Last I knew, the plan was to run a lap, and knock a ball off - maybe two.
Unread 05-03-2008, 15:54
BBnum3's Avatar
BBnum3 BBnum3 is offline
Ridiculously proud of MN First
AKA: Nat Thompson
FRC #1816 (The Green Machine)
BBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to behold
Send a message via AIM to BBnum3
There are a couple of reasons this robot will be really good this year:
1. Beachbot's drivers are always amazing.
2. The fact that the lower arms can corral the ball and the upper arms can pick it up while moving will be incredibly helpful.
Founding member of Team 1816.
Unread 05-03-2008, 16:14
Syncopation's Avatar
Syncopation Syncopation is offline
I can't make a dongle outta 25-pin!
FRC #0932 (Memorial Circuit Chargers)
Syncopation has a spectacular aura aboutSyncopation has a spectacular aura aboutSyncopation has a spectacular aura about
Send a message via ICQ to Syncopation Send a message via AIM to Syncopation Send a message via MSN to Syncopation Send a message via Yahoo to Syncopation
Amazing design and execution guys - I've seen what you've done in the past, and you might have even outclassed yourselves. Awesome robot, hope you do well!
One question (and this was the main problem for a number of robots at week 1 regionals - or maybe just St. Louis), but from the video, it looks like when you hit the overpass with the arm and let go of the trackball with the hand, you're in a position to be "clotheslined". Any ideas on avoiding this?
217 (the ever-powerful ThunderChickens) impressed everyone with their "slam dunks": they (from what I saw) could disengage their arm so that the force from hitting the overpass flipped the arm backwards so they could drive under the overpass safely (a dog gear or something like that was my guess - never got the chance to ask them myself). Probably not much help for you, since it doesn't look like you guys can rotate the arm past vertical to the back, but just a thought. Might want to watch out for that.
Anyway, you guys have a great design (I never would have thought of two arms organized like that) and best of luck to you in your regionals and championship!
[I apologize for the novel here, just a thoughtdump more than anything.]
Team 932:
2008 Oklahoma City Xerox Creativity Award
2008 Oklahoma City Autodesk Visualization Award
2008 St. Louis Chairman's Award winner
Home of the 2008 St. Louis Woodie Flowers mentor
2007 Kansas City Engineering Inspiration winner
2006 Lone Star Regional Finalist alliance member
A mathmatician, a physicist, and an engineer were all given a red rubber ball and told to find the volume.
The mathmatician carefully measured the diameter and evaluated a triple integral.
The physicist filled a beaker with water, put the ball in the water, and measured the total displacement.
The engineer looked up the model and serial numbers in his red-rubber-ball table.
Unread 05-03-2008, 16:22
ShaneP's Avatar
Thanks for the compliments.
We've hit the overpass in high gear going as fast as the robot will go, and even though it does close-line, it does not fall over backwards. The wheels still stay on the ground enough to backup the base. If need be, we can hurdle backwards as well.
Unread 05-03-2008, 16:27
I foresee a regional victory this weekend.
Unread 05-03-2008, 16:43
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
The rugby player video is the best. Playing the Rocky video. Everyone needs to see that, its hilarious. The robot definatly won that battle
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 05-03-2008, 16:56
Ah, cool. Just a thought. Any worries about being bumped by passing robots adding to the tipping? Chances of falling on your back are probably slim, though. Hah, what am I saying? Your robot can withstand a rugby player kick - more than I can say about myself.
Good luck, and I'm excited to see you guys in Atlanta!
Team 932:
Unread 05-03-2008, 17:11
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
Another amazing robot from the guys ( and girls) from Hope Chapel. I'm really looking forward to this weekend.
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Unread 05-03-2008, 17:18
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We can pick ourselves up from any direction we might fall, using either the herder, the arm, or both.
We still have to qualify for Atlanta (and then fundraise).
Unread 05-03-2008, 17:59
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
WOW! its sooo.. simple yet so efficient see you in la. whats the max fps you guys can do?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 05-03-2008, 18:19
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
We are doing 6.5fps in low and 15fps in high.
There is most of the information on our robot here, http://team330.org/?q=content/2008-robot-unveiled
Unread 05-03-2008, 19:13
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
Team Role: Tactician
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
Not to hijack the thread, but I just wanted to make a note here. Although we originally had a dog gear clutch designed in the arm gearbox (good guess haha), we found it was easier to just time a simultaneous release the ball + stop the drive momentarily + start pulling back the arms. I'm sure that after practice 330 will adopt a similar strategy.
Tip coming from someone who did just that at STL - the crowd will looovvve it We had people coming up to us all day, "that was soo cool how you picked yourselves up" etc.
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 05-03-2008, 20:22
mark johnson's Avatar
mark johnson mark johnson is offline
FRC #3175 (knight vision)
mark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud of
Another awsome bot from THE BEACH BOTS!!!!! From your 2007 Currie Championship partners and IRI partners. Good luck this weekend and the rest of the year. Hope to see you in Atlanta and IRI. Mark
K.I.S.S.
Unread 05-03-2008, 21:05
Rookie Year: 1997
Originally Posted by Travis Hoffman View Post
Anyone thinking 254 2004 with this one?
The lower tusks remind me of the ball herding legs that popped out on that bot.
Looks slick.
We get inspiration from a lot of teams, 254, 60, and especially 71 (and probably a bunch more that I'm forgetting).
2008 Offseason event MARC being moved to JUNE 28, 2008 Steve Ketron Off-Season Events 10 21-03-2008 07:55
pic: 1493 2008 JamesBrown Robot Showcase 5 24-02-2008 14:02
pic: HOTBOT 2008 WEHickok Robot Showcase 16 24-02-2008 08:31
2008 Pre-Ship 2008 Suffield Shakedown Scrimmage Webcast stevek General Forum 0 13-02-2008 23:55
Congrats to Beachbot on winning the chairman's award Joe Ross Thanks and/or Congrats 6 07-04-2003 01:10
