Thread Tools |
Rating:
Display Modes |
#11
Re: pic: Fully Automatic Tee Shirt Cannon - Pic 2
Thanks for the positive feedback!
It seems my first picture for some reason never made it into CD Media, where I had a long description of the robot and mechanism and a shot from another position. Oh well... Anyway, this tee shirt launcher will be mounted on top of the Mountain Dewbot (now with a lot of modifications) that I built last year for Mountain Dew. (The top "can" on the robot will be about a foot shorter, and the sound system inside it is now a full-blown car stereo system, with a 4x increase in the audio Wattage!) This was a test of concept air cannon my father and I made last summer, with about $80 of parts from Home Depot. With that in mind, I decided to do with this air cannon what I always do when designing stuff... and hence, we get this. ;-) This, is the mostly completed CAD model for the new gem on the robot, the tee shirt launcher. I designed and CAD'ed this entire mechanism in about three and a half days. Since I only have about twelve to fifteen days to fully manufacture it, I wasn't able to design as much CNC milled parts as I would like. (Setup and probing would probably take longer than just making many of these parts manually...) The vast majority of the brackets were design to be milled on a manual mill or a person with tight tolerances on a drill press, and 80/20 was chosen as the structural member in place of fancy milled aluminum plate. Because this mechanism was designed to be the key feature on a public relations robot, I had to pay a lot of attention to detail and looks, as well as making it functional. A lot of the parts will be spray painted glossy black (I would have preferred powder-coating, but again time is my enemy), with a few parts left as lightly sandblasted aluminum finish. The barrels are going to be spray painted a bright green, with a clear stripe left along them to tell from the side if there is a tee shirt in that barrel. The tubes are UV resistant Lexan for safety reasons, since they are rated for 9000 psi. There is a rubber O-Ring and chamfered ends of the shafts to ease the transition between the different sections. The accumulators you see are only for the pneumatic cylinders; they are on a check valve to ensure right after a launch there will be enough pressure there to at least open the cylinders to advance the to the next barrel while the system recharges. There is one (2" bore, 2" stroke) on a 4:1 leverage arm to push the rear plug into the barrel cassette. The top one on the extender is a 1.5" bore, 0.5" stroke. There will be a third 0.5" bore, 0.5" stroke (not yet pictured) to "snap" the cassette into position to ensure everything is lined up. The main accumulator is a 3" diameter, 18" long aluminum air tank (not pictured), with 1" pipe/tubing between it and the barrel. System recharge time to full 120 psi launch pressure is about 90 seconds with a KoP compressor. Now, onto some more pictures! Note: I had all the mates in Solidworks correctly to simulate the linear motion for the linkages, however the pneumatic cylinders have yet to be mated, so none of the motion is currently simulatable And oh yeah, I didn't model any of the fasteners or e-clips. Oh well, I know from the hole size what my original intent was. ;-). Note: in this slot the delrin linear sliders are a bit shorter than they will be on the finished robot. Trying to keep costs down, the assembly as shown only used a single foot of 1" x 1" delrin. But I'm worried about torque from the pneumatic cylinder causing this piece to jam, so I'm going to make it longer. ![]() ![]() ![]() ![]() Because the linkage arm is transferring linear motion in an arc to linear motion along a line, the hole at this end of the linkage arm is slotted. ![]() |
| pic: T-Shirt Cannon at Purdue's Homecoming | jtdowney | Extra Discussion | 10 | 11-08-2007 07:48 PM |
| IRI T-shirt cannon | Kyle Love | Off-Season Events | 6 | 07-17-2007 12:09 PM |
| pic: 549's t-shirt cannon and ballon inflator w/ horn | griff549 | Extra Discussion | 2 | 05-06-2007 12:36 AM |
| pic: FRC1341's 2007 Robot Fully Deployed | Adam Richards | Extra Discussion | 5 | 03-05-2007 10:28 AM |
| Tee-Shirt Gallery | rodgadashruba | General Forum | 5 | 10-11-2006 06:53 PM |
