Re: pic: Three Trackballs?
Now you guys have got me wondering. A quick search found me this photo which may exhibit my thinking.
The ends of the field where the drivers are have the big lexan panels. The angled corners are the chainlink fence. The center divider are 3 high lexan panels. The low outside sidewalls have lexan, but the outer outside walls are just the metal pipe - no lexan. At least I can't see any. There are no zip-ties holding the panels anyway, like the center divider wall has. I remember at the end of Final matches before the awards they were taking the pipes down on the audience side but no lexan. I realize there is a need for a protector/divider both at center divider and the long side walls, to keep the trackballs from going all over the place, but the lexan? Keeping robots on own side? Make a rule against it, or add another horizontal pipe. Entangling? Well, the robots do that now on the overpass. I'm sure there was a reason. ![]() |
I always figured it was to prevent manipulators and/or robots from "trying" to go through the center divider, that is the drive base goes under the lowest section of horizontal pipe and your manipulator gets demolished as your entire robot attempts to take a "short cut." It also presents a "solid" object on the "left" to bounce ultrasonic range finders off of.
The bases of the outer walls are placed outside the normal side rails of the field. The outer walls have no polycarbonate panels, and have smaller diameter pipes than the inner walls. They also require little or no maintenance during the competition. From the differing construction, I conclude that the purpose of the center divider is to prevent both trackballs and robots from crossing the center of the field, so it has to be strong enough to withstand lots of rough treatment. But the purpose of the outer fences is merely to keep the trackballs from escaping. So they are neither as robust nor as impermeable as the center divider. Furthermore, I suspect that the GDC knew very well what the effect of reflective panels would be. After all, they DIDN'T use the stuff on the corner panels. ![]() |
the reflections on the opposite end of the field are extremely distracting. When driving into the other corner its like going in blind. During a practice match I ran into our own partners, who I didn't see, that were trying to pick up the ball.
Oh well, just another element to the game. -Sam |
) how the center panels act. But I don't think they purposely designed it that way: they probably figured it would be part of the game -- a classic "it's not a bug -- it's a feature!"I would think if the middle row of panels were removed and another horizontal bar put in would be a better alternate -- do not cross or you will get entangled (or get your parts sliced off!) might be enough of a punishment. I'm thinking of all those robots that tangled up in the overpass. The sonar can still bounce off the bottom panels, either the inside wall or the outer wall. After all, the outside wall is low anyway. Last night I tried standing in front of our drivers as they practiced. They got annoyed until I show them those photos. "Oh yeah..." Then we tried the "use the force Luke" approach -- close your eyes and use verbal commands only. Good thing our Robo-Coach has those hand-signals... Quote:
; but I did fear my "the outside outside 'protector' walls (if you follow me)" didn't quite emphasize which I meant. |
| pic: Three wheel | Redo91 | Robot Showcase | 8 | 18-02-2007 15:14 |
| pic: Three colors??? | natis | Extra Discussion | 24 | 09-11-2006 18:40 |
| pic: My three sons | Rich Kressly | Robot Showcase | 11 | 22-02-2006 20:46 |
| pic: Three teams one robot | Bcahn836 | Extra Discussion | 9 | 20-03-2005 18:44 |
| pic:THREE PICS OF NEW ARM!!!! LOOK!!!!!! | sgsdragons | Robot Showcase | 0 | 13-02-2005 22:37 |
