Go to Post P.S. Who doesn't have CD as there homepage! (I mean, come on people. It's not like there's anything else to do on the net... :)) - Ryan M. [more]
Unread 14-03-2008, 03:39
KarenH's Avatar
Happy Birthday! KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
Re: pic: Three Trackballs?
Originally Posted by Roger View Post
The ends of the field where the drivers are have the big lexan panels. The angled corners are the chainlink fence. The center divider are 3 high lexan panels. The low outside sidewalls have lexan, but the outer outside walls are just the metal pipe - no lexan. At least I can't see any. There are no zip-ties holding the panels anyway, like the center divider wall has. I remember at the end of Final matches before the awards they were taking the pipes down on the audience side but no lexan.
Oh, the OUTSIDE ones! I was thinking of the normal field walls. You're right, those don't have any visible. I'd say that's so refs, spectators, and camera people have a clear view with no chance of reflection.
You're both correct. The center wall has larger diameter pipes, and the reflective panels are laced in place with substantial cable ties. The look reminds me of leathercraft projects from childhood day camps (moccasins?). The bases for the uprights are covered with carpet pieces. The thing is a bit of a nuisance to assemble, and the cable ties are a nuisance when taking it down, but it looks to me like the greatest nuisance for the field crew is keeping the carpet pieces securely taped down. One robot in San Diego ate one of the carpet pieces, along with the sticky tape, and got "indigestion."
The bases of the outer walls are placed outside the normal side rails of the field. The outer walls have no polycarbonate panels, and have smaller diameter pipes than the inner walls. They also require little or no maintenance during the competition.
From the differing construction, I conclude that the purpose of the center divider is to prevent both trackballs and robots from crossing the center of the field, so it has to be strong enough to withstand lots of rough treatment. But the purpose of the outer fences is merely to keep the trackballs from escaping. So they are neither as robust nor as impermeable as the center divider.
Furthermore, I suspect that the GDC knew very well what the effect of reflective panels would be. After all, they DIDN'T use the stuff on the corner panels.
Karen Husmann
Ex Robo-widow
Unread 14-03-2008, 05:48
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
the reflections on the opposite end of the field are extremely distracting. When driving into the other corner its like going in blind. During a practice match I ran into our own partners, who I didn't see, that were trying to pick up the ball.
Oh well, just another element to the game.
-Sam
Unread 14-03-2008, 09:21
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
The corner chainlink panels -- wasn't that so the IR can go thru it? But I agree GDC must have seen (or not ) how the center panels act. But I don't think they purposely designed it that way: they probably figured it would be part of the game -- a classic "it's not a bug -- it's a feature!"
I would think if the middle row of panels were removed and another horizontal bar put in would be a better alternate -- do not cross or you will get entangled (or get your parts sliced off!) might be enough of a punishment. I'm thinking of all those robots that tangled up in the overpass.
The sonar can still bounce off the bottom panels, either the inside wall or the outer wall. After all, the outside wall is low anyway.
Last night I tried standing in front of our drivers as they practiced. They got annoyed until I show them those photos. "Oh yeah..." Then we tried the "use the force Luke" approach -- close your eyes and use verbal commands only. Good thing our Robo-Coach has those hand-signals...
Methinks that hat is on too tight EricH ; but I did fear my "the outside outside 'protector' walls (if you follow me)" didn't quite emphasize which I meant.
pic: Three wheel Redo91 Robot Showcase 8 18-02-2007 15:14
pic: Three colors??? natis Extra Discussion 24 09-11-2006 18:40
pic: My three sons Rich Kressly Robot Showcase 11 22-02-2006 20:46
pic: Three teams one robot Bcahn836 Extra Discussion 9 20-03-2005 18:44
pic:THREE PICS OF NEW ARM!!!! LOOK!!!!!! sgsdragons Robot Showcase 0 13-02-2005 22:37
