Re: surefire ways to break you robot
Upon entering FIRST you immediately apply Murphy's Laws.
ONE OF OUR COACHES TRIPPED ON OUR FTC BOT
THAT'S RIGHT MR. GRIMES, I'M PUTTING YOU OUT THERE Last edited by NorviewsVeteran : 21-12-2008 at 15:04. |
Forget to secure the battery so it falls out of its holder...and onto the main breaker.
Find a minor problem and say, "I can fix that." It will turn into a major problem.
Alternately, say, "I can make that work better." |
I think that was the reason why the mentors wouldn't let me make some changes to the robot that would make it work better...
Say, "we will get it after the next match",
Responding yes to "Is it fixed?" Any time They call for the Pits to clear |
-Cross wire the speed controllers. Fortunately we realized what we'd done before we turned the robot on.
-Forget to replace broken fuse. -Forget to tighten zipties after replacing battery These are all things we did with a test bot earlier this year. |
-when figuring where to put the battery, remember to drop the uncovered contacts directly on the metal frame. TWICE.
seriously though, kick it away with your RUBBER SOLED SHOE |
Don't loktite the set screw on the CIM shaft.
Go full speed off any kind of ramp. Not bother making an enable/disable dongle. Use cheap limit switches to halt your lead screw's travel. Overconfidence. |
#10
Design, Wire and Maintain your robot so that shorts are not probable. Electrical layout should be the responsibility of both the mechanical/design teams and the electrical teams. Don't ever get into the us vs. them mentality. If you're mechanical and don't go out of your way to make electrical easier, you can't complain when it fails. Your wire runs should be clean, organized, labeled and easy to differentiate between wires. If you have a short, or a motor not working somewhere, etc... you want to spend as little time possible finding what wire is hooked to what. Electrical failures suck, they can cripple a mechanically perfect robot, and can be difficult to fix and diagnose. Same goes for the relationship between mechanical/design and programmers. Make it as easy as possible for them... You are the SAME team afterall |
#11
![]() Also, wiring through holes with sharp metal jagged edges. |
#12
- Drive the robot during a match where important school board of directors are watching.
- Deciding during the regional that after your robot can barely drive, you need to have some super-cool autonomous mode programmed before the next match. - Assign a non-mechanical member a very critical task between regionals |
#13
When your school building is surrounded by windows (Which we have) and you test autonomous mode in that hallway for the first time without the bumpers on. The robot was not the only thing broken after that.
#14
...Get picked by the number one alliance. Scream and cry because the alliance is awesome and there is no way you won't go to Atlanta. Scream and cry as the alliance's robots' motors burn out and arms get bent. Lather. Rise. Repeat.
EDIT: I'd also like to add that you guys are abusing the crap out of the programmers. (Although I'm not any better...) Last edited by Katie_UPS : 26-12-2008 at 22:59. |
#15
Tell Renee to tighten the electrical block. (She then loosens the electrical block >_>)
| MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." | Mr MOE | General Forum | 0 | 03-02-2008 16:37 |
| pic: strange ways you test stuff out? | DarkFlame145 | Robot Showcase | 1 | 13-01-2008 15:10 |
| MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" | Mr MOE | General Forum | 6 | 09-02-2007 08:40 |
| What do you do when its time to take a break from building?? | Leo 1529 | Chit-Chat | 23 | 13-02-2006 00:26 |
| MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." | Mr MOE | General Forum | 3 | 15-02-2005 11:38 |
