Go to Post If you don't have anything nice to say, don't say it all. I mean, I know we all get frustrated during build season, but we still need to make an effort to be polite and helpful. - Karthik [more]
Unread 26-03-2008, 14:30
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Re: pic: 1625's swerve module (better pic)
Originally Posted by A_Reed View Post
how is the lower plate supported? I know it used as a bearing surface, but it is sandwiched between plates or riding on small ball casters. I have always wondered how this work with swerve modules, I understand the rest of it but the lower support plate is the only gap in my limited knowledge of drive systems(I don't go into the kinematics...yet).
The lower plate isn't necessarily a support plate, just a bearing surface like you said. Due to the nature of friction, it does a little support, but mainly it just rubs against flat plastic patches (lubed up to reduce friction) on the frame to aid in steering the modules. The face of the contact between the plastic and the plate is purely vertical. No horizontal contact is made between the plate and the frame. It is welded, in the corners, to the square tube that makes up the vertical body of the module.
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
