Go to Post Every robot needs a locky-thingy. A robot without one might fire when it isn't supposed to, and hit the wrong target; e.g., a referee, FTA, or robot inspector. - Richard Wallace [more]
Unread 31-03-2008, 15:53
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Re: pic: What Happens When You Go Too Fast...
That's not from going too fast. Most likely you lifted one drive side of your robot off the ground and held it at full throttle. When it came back down the momentum in the drive train tried to put all that energy to the wheel and snapped the spokes. In race cars when you hop a tire at WOT you can blow a rear-end, drive shaft, axle shaft or transmission. Even when I used to race RC Trucks, when you came off a jump you had to let off the throttle or you would shatter titanium axles as you hit the ground. It comes down to driver error when this happens.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
pic: What happens when you mess with 709 Priyadarshy Extra Discussion 2 22-03-2007 17:47
pic: Whoops... What happens when you change 6v FP to 12v FP? team222badbrad Extra Discussion 2 21-02-2005 10:06
pic: What Happens When You Work In Rural New Hampshire Petey Extra Discussion 9 13-02-2005 10:38
pic: This is what happens when you don't win in NYC CD47-Bot Extra Discussion 5 07-04-2003 18:10
