Go to Post We should also remember the fact that the FIRST Manual is not supposed to be enterpreted with lawyer speak. If so you could make it say many things. - Anthony [more]
Unread 12-04-2008, 08:40
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Re: pic: Team 1114 - Simplicity in Design
"Simply" awesome!
Thanks for sharing, Karthik!
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
Unread 12-04-2008, 08:48
Billfred's Avatar
Billfred Billfred is offline
It's documents like this that make even us business majors really appreciate how utterly awesome a mechanism or robot is. (254/968 last year won the prize for their gearbox poster.)
I'll say it: 1114 is serious business.
Unread 12-04-2008, 09:00
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Originally Posted by waialua359 View Post
That was my guess. You can clearly hear it even on webcast matches when your arm rotated. Must be pretty loud.
By the way, how did you get the 72 tooth sprocket? Go-Kart type? We used an 84 tooth last year and 72 this year and that's the most common question we get about our robot.
It was a custom job, machined out of aluminium on their CNC.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 12-04-2008, 13:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
This machine truly embodies "simlpicity on the other side of complexity"
Unread 12-04-2008, 19:54
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
As a rookie team, we've noticed that simplicity pwns complexity...
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 12-04-2008, 20:18
Jno
FRC #0610 (Crescent Robotics)
As I said earlier in the year before I even saw this bot that it is by far the simplest bot i've seen from 1114. Now that I've had time to look at the details of this bot I've had a couple "why the heck didn't I think of that" moments.
Originally Posted by Jonathan Norris View Post
when you compare this year's bot to every other bot they have produce it is by far the simplest bot they have ever built, no amazing box stacker, no platform climbing crab drive with hanging arm, no double jointed arm, no tank drive poof ball shooter, and no folding ramp with a 4-bar arm that fit within 4" (or something ridiculous like that). I would say their '06 bot was fairly simple, but when you look at their mechanism this year its what, a single joint with a roller manipulator and a 'punch' kicker (its pretty simple mechanism), I would say their bot is a very simple solution to this year's game. When you compare it to what a lot of the other 'top' teams came out with looks fairly darn simple to me, maybe its just the machining quality that makes it look more complex then it is.
I am still surprised that no one came up with a similar concept, the closest i've really seen is 1625 (and their great bot is still far more complicated). Some bots use similar pick up, but very few teams use the pokie type of launcher that fits so well with this design.
Co-Founder of Taplytics.com
Unread 12-04-2008, 21:23
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
similar designs were probably thought of by many, unfortunately, they must have thought "i cant figure out how to launch the ball" or "we cant fit that manipulator into the starting position" or other similar considerations. i think the most crucial part to many designs this year was a winch that allowed them to store and release the necessary energy to catapult the trackball. teams that developed this mechanism were able to utilize a simple design such as this.
Unread 12-04-2008, 22:54
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
That robot is simply amazing. Its definitely one of those robots that i look at and wonder "how did i not think of that?"
The closest our team came to a shooter was a pair of skis... it launched the ball a fair amount (almost too high- it would hit the ceiling in our practice arena), but was extremely unsafe and lost the ball often (hence why our current bot keeps an iron grip on things).
Id say you guys pulled off the shooter concept wonderfully. You guys get an ÜberStar:
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 13-04-2008, 01:53
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
I dunno, our shooter is pretty simple if you get a good look at it. Our drive train is much more complicated, being a swerve and whatnot, but our shooter cocking mechanism was inspired by a Lego creation of one of our seniors a few years back (yes, people still play with Legos ). We had JVN down at our pit at the Wisconsin Regional having an infamous "why the heck didn't I think of that" moment in relation to our shooter.
ps: Kudos to 1114 for dominating, btw. Your entire setup is sick.
Last edited by hillale : 13-04-2008 at 01:54. Reason: figured i'd contribute to the thread
Unread 22-04-2008, 15:19
ttldomination's Avatar
Sunny
This may seem a little bit late, but could I get a description of how the winch works?
I'm kind of confused about how they pull the bar in?
1648: 2013-2014
5283: 2015
pic: Team 1114 Teaser Brandon P Extra Discussion 43 24-09-2008 20:28
pic: Team 1114 Drive team in the finals Dan 1038 Extra Discussion 30 24-03-2008 22:08
pic: Team 1114 - Simbot SS Karthik Extra Discussion 30 08-03-2008 13:21
pic: Team 1114 -- Simbot Prime Karthik Extra Discussion 62 31-07-2007 23:12
pic: Team 1114 Gearboxes CD47-Bot Robot Showcase 16 19-02-2004 12:16
