Go to Post Some advice I wish I had as a college freshman: If you don't understand it, or are struggling to keep up, ask for help. - DonRotolo [more]
Unread 04-12-2008, 01:41 PM
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
pic: Say Hello to MAX 4
Unread 04-12-2008, 01:42 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Say Hello to MAX 4
Wait...so you got better....again!?!
There goes your biggest weakness. Good luck in Atlanta.
Unread 04-12-2008, 02:04 PM
Ken Delaney 357 Ken Delaney 357 is offline
FTC #101(Radnor Robotics)
FRC #0357 (Royal Assault)
Ken Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to behold
I got to take a close look at it during NYC FTC. One of the most interesting aspect of the robot is its onboard autonomous selection method. Just above the "Teen" sign you will see two bevel gears stickin out of the robot with no apparent purpose. The shaft thats holds the bevel gears are attached to potentiometers which monitor the position of the gears and set the autonomous mode accordingly. They use the bolts around the pot to keep the gear aligned using metal attached to the gear so that it does not change settings. It is an impressive bot.
“Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat.” ~Teddy Roosevelt
Thus spake the master programmer:
"A well-written program is its own heaven; a poorly-written program is its own hell."
Unread 04-12-2008, 02:22 PM
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Do MAX 4 use an auto sort system for the rings? I know I've seen one on a vex bot before, I think it was '06.
-Dustin Benedict
Unread 04-12-2008, 03:04 PM
Lowfategg's Avatar
AKA: Tyler Moser
Yes it can but because of changes in lighting we don't use it during real matches. Can't wait for that real color sensor in the new kit.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 04-12-2008, 04:20 PM
thefro526's Avatar
Mentor for Hire.
Have you ever tried making a completely dark box for the rings to pass through and then using the IR line sensors to read color to read them because they can work with no light.
-Dustin Benedict
Unread 04-12-2008, 04:34 PM
Lowfategg's Avatar
AKA: Tyler Moser
We had an idea like that but we never built it.
Unread 04-12-2008, 05:05 PM
thefro526's Avatar
Mentor for Hire.
You could put like a whole bunch of signs around your collector to block out the lighting. But yeah you guys are smart for not trying it in ATL because the light changes as the day goes on the the dome.
-Dustin Benedict
Unread 04-12-2008, 05:16 PM
Lowfategg's Avatar
AKA: Tyler Moser
Ya you can tell light is a problem when you stand next to the robot and it thinks your a ring. Its very cool but not reliable.
Unread 04-12-2008, 08:29 PM
astephen68's Avatar
astephen68 astephen68 is offline
Build, Scout, Drive
AKA: Stephen
VRC #0478 (Mustang Robotics)
Team Role: Scout
astephen68 is just really niceastephen68 is just really niceastephen68 is just really niceastephen68 is just really nice
Cna wiat to meet you guys in Atlanta
Soutern Ontario Championship
-Finalists
-Winners of the Drivers Challenge
-Finalists
Unread 04-12-2008, 10:08 PM
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
The robot I saw at Snowday Showdown was amazing, I'm sure I'm in for an even bigger shock at the Championship! Best of luck guys!
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
pic: Can you say cheese? falconmaster Extra Discussion 7 02-10-2008 09:05 PM
pic: FIRST logo in 3DS Max fimmel Inventor 9 05-29-2006 12:11 AM
pic: Hanging (or should I say "curling") CD47-Bot Robot Showcase 10 03-06-2004 10:51 PM
Joystick max VS. motor max archiver 2001 4 06-24-2002 01:01 AM
Say hello to team 173 Joel J Robot Showcase 5 04-06-2002 08:33 PM
