Go to Post The battery needs to be velcro-ed, strapped, buckled, tied, bolted, glued, zipped, or stapled in place so that it can't fall out when (not if) the robot turns upside-down. - dlavery [more]
Go Back   Chief Delphi > Technical > Control System > FRC Control System
Unread 21-04-2008, 15:16
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Re: pic: 2009 Control System, Mounted
It doesn't take up as much space as you think, mostly because you are replacing the backup battery, the power distribution blocks, and the 40 amp fuse blocks, as well as spikes for punematics. It is going to be heavier though.
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
NEW 2009 Control System Released qnetjoe FRC Control System 296 15-08-2008 15:02
2009 Control System Possibility? Racer26 Rumor Mill 121 25-04-2008 09:05
New System for 2009 Lafleur Programming 1 17-04-2008 21:45
pic: Team 116 Modular Control System dlavery Robot Showcase 42 21-10-2007 11:15
2009 control board? Stuart Rumor Mill 4 14-05-2007 19:01
