Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 21-04-2008, 21:34
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: pic: 461's Drive Pod 2.6.2008
Kind of resurrecting this post but how thick is the metal?
Unread 21-04-2008, 22:21
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Hi Andy,
The metal on the inner plate (the one that interfaces with the AndyMark gearbox) is 1/4". I wanted to make only the section interfacing with the gearbox 1/4" due to bearing clearances, and then the rest of it 3/16", but I also didn't want to plague our machinists, either. The outer plate is 3/16". The weight-reduction holes could have been more aggressive too, but yeah. The pod was designed before the season and we didn't really want to change it even after we found out the game, so the gear ratio was a little slower than it should have been for this year (it was designed for politely escorting, as the term is around here.)
If you have any other questions, let me know.
Nikhil
Unread 22-04-2008, 10:01
Racer26 Racer26 is offline
The pod itself looks alot like 1075's in size and shape, but ours have a track instead of wheels, and our motors, gears, and shifting transmission are all housed inside the unit. 4 pins with clips and an electrical connector and a unit can be replaced with a spare.
At GTR we had a match with about a 30 minute turnaround, we broke both tracks. We had the spares on it, tested, working, ready to go, and we only missed the match because queueing falsely thought the match was underway and wouldn't let us in.
EDIT: and since the spares hadn't been used on the competition bot before, we had to drill all the holes for the bumper mounts in them, which took most of the time.
Unread 22-04-2008, 10:11
ktbcantrell ktbcantrell is offline
Designer, animator, builder, driver
FRC #1771 (Unknown Error)
ktbcantrell is on a distinguished road
sweet looking drive tracks.
Team 1771
2008 Driver - Archimedes Division - XEROX creativity award winners
2008 Driver - Peachtree Regional
2007 Driver - Internationals
2007 Driver - Bayou Regional Champion (thanks 1912 and 462)
2007 Driver - Peachtree Regional
Unread 22-04-2008, 11:19
MATLAB Fan
What do you mean by "housed inside the unit"?
Unread 22-04-2008, 12:08
Essentially instead of driving the tracks drive wheels externally, the drive hub (two 'wheels' on either end of the units support the tracks [tracks made by brecoflex]). The driven 'wheel' is cut in half along its circumference, and a sprocket mounted inside it. This sprocket is driven by a custom chain (no joining link) to a smaller sprocket, which is mounted to a bevel gear. the other bevel gear is mounted to the output shaft of the transmission, and the input shaft of the transmission runs along the long axis of the unit. the input shaft is driven by two CIM's per side, mounted below the mainline shaft, connected by short chains. if you think of the track itself as being an oval, the wheels that drive it, the transmission, and the motors are all inside the oval, and only 4 pins actually interface with the main chassis of our robot, so changing out a broken drive doesnt involve replacing gears on motors, or any of that stuff, we just build spares, ship em with the robot, and an entirely new drivetrain could be put on in just minutes.
Team 007 - 2008: Thunderbot - Drive Kendal Reed Robot Showcase 12 05-02-2008 18:29
2008 Omni Drive Code Help Vasily Zaitsev Technical Discussion 5 27-01-2008 00:57
2008 Over Drive Manual Jaime65 General Forum 22 05-01-2008 21:49
pic: 461's black frame Logan Byers Robot Showcase 11 11-02-2005 22:16
Thank a Team with an i-Pod !!! OZ_341 General Forum 8 20-04-2004 23:57
