Go to Post Of course, every team in FTC should be asking the magic question: "What would Simbotics do?" - Billfred [more]
Unread 22-04-2008, 10:07
Racer26 Racer26 is offline
Re: pic: The new driver station
Wow... if the dashboard capabilities had enough throughput, mount a tri-axial turret on the top, with a camera on the end of it. basically turn the laptop into an FPS, mouse moves the turret in 2 axes, q and e in the 3rd axis, wasd to move the holonomic drivebase, and you feed the camera out onto the laptop screen... crosshairs in the middle of the screen, adjusted so that clicking the mouse fires a (ball, tshirt, whatever) perfectly for the crosshaired target... Cool.
EDIT: On second thought, your turret only needs 2 axes... though q and e could be used to rotate the drivebase.
pic: Why FIRST needs to make the driver station taller Jay Trzaskos Extra Discussion 12 12-03-2007 08:57
Have Any New Driver Advice? thefro526 General Forum 38 27-02-2007 13:49
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
