Go to Post To me, FIRST is about having students realize that there IS an answer to the age old high school question: "when are we ever going to use this crap?" - Chris Hibner [more]
Go Back   Chief Delphi > Technical > Control System > FRC Control System
Unread 22-04-2008, 10:20
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: pic: 2009 Distribution Block
Originally Posted by 1075guy View Post
Well, we were by no means the only team that had the current PDB continually throw wires on us, though for 2008 we came up with a way to make it literally impossible for the wires to come out of it.
The connections on the new PD are nothing like the ones on the rockwell block - they are not set screw terminals but rather Wago terminal blocks. They are hard to describe - but essentially you stick a screwdriver in and lift to make a place for the wire to go, and then it springs into locked position when you remove the screwdriver. I don't know the exact spec but after playing with them I would imagine you can pull with 50+ lbs of force on a 12ga wire and not have it come out.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
distribution block Magnechu Electrical 11 14-02-2008 19:07
Distribution Block Magnechu Electrical 3 04-02-2008 21:38
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
