Go to Post If you don't like contact, your robot is not built well enough. - sanddrag [more]
Unread 23-04-2008, 12:01
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Re: pic: The new driver station
Originally Posted by jimsmith2354 View Post
Yeew, those header pins are nasty - can you say protective cover needed...
The USBs will also need some retention means to keep them in place when a robot hits the wall. All the talk of writing your own Java is great - except for the novice and other teams with little programming support. All in all, the FIRST hardware and software gets better each year, so no worries here.
Don't worry. There is a metal/ plastic cover in the works. Also, the header pins are going to be at a right angle to how they are now. This will allow connections to be made from the side instead of the top.
Originally Posted by richardmcc2 View Post
From what they said at the mentor info session, a dashboard computer can be connected via one of the USB ports, and there was a certain packet size that could be sent bidirectionally between the control station and the laptop.
The lower of the two Ethernet ports is for connecting to a laptop dashboard. It can also be used to "daisychain" several Driver Stations together so they can use the same WAP. The USB ports are only inputs for joysticks/ wheels/ gamepads etc. I don't have any info about the amount of info available through the dashboard port however...
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
pic: Why FIRST needs to make the driver station taller Jay Trzaskos Extra Discussion 12 12-03-2007 08:57
Have Any New Driver Advice? thefro526 General Forum 38 27-02-2007 13:49
Serial Driver and 2K6 Encoder Driver Not compatible Tom Bottiglieri Programming 6 12-02-2006 01:11
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
