Re: pic: 1565 Linkage Troubles
You could probably get away with cutting the flange off the angle for several inches at each end. The dimpled center idea is good too, if you can figure out an easy way to do it. This is pretty common in linkages on real life machines (for example the flat bar that connects the inner door handle in a 1950s chevy).
| pic: 1565 Twitch the missing Linkage Ball hold | T3_1565 | Extra Discussion | 13 | 30-03-2008 14:00 |
| pic: 1565 Twitch the missing Linkage Underbelly | T3_1565 | Robot Showcase | 12 | 17-03-2008 13:58 |
| pic: 1565 Linkage Drive System | T3_1565 | Extra Discussion | 10 | 13-02-2008 15:44 |
| pic: 1565 Extended Version | T3_1565 | Extra Discussion | 5 | 04-02-2007 22:20 |
| pic: 1565 Compact Version | T3_1565 | Extra Discussion | 2 | 04-02-2007 20:37 |
