Go to Post There's a balance to it all, when the engineers guide the students, and both cooperate to build a robot. There can be no better way then when both sides are in cooperation - the true spirit of FIRST. - Jim McGeehin [more]
Unread 25-04-2008, 12:57
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: pic: 1565 Linkage Troubles
Originally Posted by squirrel View Post
You could probably get away with cutting the flange off the angle for several inches at each end. The dimpled center idea is good too, if you can figure out an easy way to do it. This is pretty common in linkages on real life machines (for example the flat bar that connects the inner door handle in a 1950s chevy).
lol.. seems like we found that dimple idea from somewhere eh??
pic: 1565 Twitch the missing Linkage Ball hold T3_1565 Extra Discussion 13 30-03-2008 14:00
pic: 1565 Twitch the missing Linkage Underbelly T3_1565 Robot Showcase 12 17-03-2008 13:58
pic: 1565 Linkage Drive System T3_1565 Extra Discussion 10 13-02-2008 15:44
pic: 1565 Extended Version T3_1565 Extra Discussion 5 04-02-2007 22:20
pic: 1565 Compact Version T3_1565 Extra Discussion 2 04-02-2007 20:37
