Go to Post Part of being an effective leader is knowing your own personal limits. - artdutra04 [more]
Unread 27-04-2008, 15:09
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: Sum of team numbers versus match number in Curie
Originally Posted by Mr B View Post
I hope that the algorithm wasn't built upon the assertion that lower numbered teams means veteran and therefore better robots. Although that might be generally the case, all teams have up or down years. I'd hate to be a low numbered team that lost their corporate support (I know several) and had to face nothing but low numbered teams. By the same token, I wouldn't want to be a high numbered team that was hot but skated through qualifying because of easy matches. The method of match selection is WAY better than in '07, but it looks like it still needs a little tweaking.
The algorithm is definitely not built on such an assumption. As Rick mentioned above you can read all about the algorithm here:
http://www.idleloop.com/matchmaker/
This is a pretty good description of the software in mostly low-tech understandable terminology. It's really a must read for anyone commenting on the pairings.
Match scheduling algorithm and team numbers Joe Ross General Forum 19 26-08-2008 15:27
pic: Team Numbers in Humbling Places Sean Schuff Chit-Chat 5 12-09-2006 18:32
pic: Random Places to find Team Numbers RoboMadi Extra Discussion 21 06-05-2006 11:52
pic: Team Numbers in Stadium CD47-Bot Extra Discussion 8 02-05-2004 23:55
Help i need match numbers... Drmoofdaddy Championship Event 5 26-04-2002 18:03
