Go to Post There can never be enough recognition of a job well done. We can never say enough Thank You's. We can never measure the impact that an inspirational teacher or mentor can make on a student because it's priceless. - KathieK [more]
Unread 18-05-2008, 16:03
Re: pic: Dual FisherPrice Gearbox
Originally Posted by vivek16 View Post
I am using a 12 tooth 20 dp gear press fit onto the fp motor shaft.
Are you machining this from gear stock? If not, where are you buying one with such a small bore? Also, why not keep the existing pinion and use a 32 pitch initial stage?
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
Gearbox/ Dual Motor Setup matt111 Technical Discussion 8 02-12-2003 09:43
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
