#12
Re: pic: Dual FisherPrice Gearbox
art,
I realize the efficiency loss and think I can live with it. We are planning on water jetting these side plates (well, manually drill the bushing holes to get right diameter and just have the jet mark them with a 1/8 hole) so the material would have to be aluminum. Thanks for correcting me on my math. That was a pretty stupid mistake on my part ![]() This is not exactly a final version of my gearbox so I have room for error ![]() I also used about 1.5 times the torque that the application worked beautifully at so I should be fine. I am probably going to switch to bearings on the first stage. After some cheeseholing I got the weight of the whole gearbox down to 2.5 pounds w/o motors. thanks, Vivek Last edited by vivek16 : 18-05-2008 at 17:10. |
| White Paper Discuss: Dual-motor, dual-speed gearbox | CD47-Bot | Extra Discussion | 8 | 05-04-2004 19:24 |
| Gearbox/ Dual Motor Setup | matt111 | Technical Discussion | 8 | 02-12-2003 09:43 |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 07-10-2003 15:04 |
| Multi Speed Dual Motor Gearbox | tenfour | General Forum | 14 | 08-09-2003 13:09 |
