Go to Post Namaste. Maybe we all one day will spend our energy trying to raise our own level to match that of the competition rather than trying to tear others down. - Rich Kressly [more]
Unread 18-05-2008, 18:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Dual FisherPrice Gearbox
Originally Posted by vivek16 View Post
We are planning on water jetting these side plates (well, manually drill the bushing holes to get right diameter and just have the jet mark them with a 1/8 hole) so the material would have to be aluminum.
I think it'd be best to have the water jet cut it like 0.010 under and then ream the hole.
Whenever we get waterjetted parts the holes are usually clearance holes or tap drill holes and their diameter is not critical. Our guy cuts them slightly undersize then we open them up with the correct size drill.
I know Pink just cuts them slightly undersized and then anything that needs a bearing in it gets opened up with a reamer in a hand drill. I'd never have guessed you could get away with using a hand drill, but it sure works for them.
2001-2004: Team 100
2006-Present: Team 254
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
Gearbox/ Dual Motor Setup matt111 Technical Discussion 8 02-12-2003 09:43
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
