Go to Post just a gentle reminder not to limit yourself to just one viewpoint - every problem can and should be examined from different angles - dlavery [more]
Unread 13-05-2008, 13:10
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Beam Bending Example
Originally Posted by kramarczyk
Are we getting anything out of this? (i.e. Keep going?)
All I'm getting from this exercise is disoriented.
Don Rotolo's post talked about the stresses being greatest on the top and bottom, which doesn't match how I read the picture it's referring to. The recent images use the words "wide" and "tall", but the pictures associated with those words seem to be swapped. Help?
Unread 13-05-2008, 16:32
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Nuts... Now that I look back I doubt that you're alone.
Thanks for saying something.
This conversation started from another thread discussing frame rails getting hit from the side which is why I modeled the beam with the load from the side and now we're mixing that convention with the typical beam loaded from top convention. I'll correct the images so that the load is on top since that seems to be the easiest to understand for anybody wandering in to this thread.
*sigh* Once again, I'm making the simple complicated.
Mark
Brick walls are for other people. - Randy Pausch
Unread 14-05-2008, 11:01
DonRotolo's Avatar
Back to humble
FRC #0832
Um, sorry about that, I accept the responsibility for confusing the directions. When I wrote I was thinking of deflection force from above, but of course the image shows (showed?) the force from the side.
Just think in 4 dimensions and it'll all make sense.
Don
Unread 15-05-2008, 16:35
ZsHeRm ZsHeRm is offline
AKA: zach shearman ZsHeRm
FRC #2560 (Robodogs)
Team Role: Student
ZsHeRm is an unknown quantity at this point
Is this what your looking for.....
Unread 15-05-2008, 22:15
kramarczyk's Avatar
That is similar to the initial picture that started this thread, but the boundary conditions are different. What did you use?
It looks like three smaller loads, 2 up and 1 down, with fixed end faces on a shorter beam.
Mark
Unread 17-05-2008, 17:26
Team Role: Student
i put equal weight in each place but in differing directions....like you said the two going up are equal to the one going down all forces are equal to 200 lbs.
Unread 17-05-2008, 17:30
Team Role: Student
I also did a different one with the exact same force and placement as you and it still worked out. ( like the one you started off with )
Unread 19-05-2008, 08:08
kramarczyk's Avatar
So from looking at the previous images I think we can safely conclude that
  1. Taking weight out of the sides of a beam is preferable to taking it out of the top and bottom (where load is applied is top).
  2. A taller beam carries a load with lower stress and deflection than a wider beam, so if you need to make 'it' stronger make it taller.
New images, just for squirrel
Originally Posted by squirrel View Post
For the sake of making the discussion even more interesting, how about making several different shapes and sizes of beam, and applying the same (relatively small) load to them and showing them all? For example, you might have rectangular tubing with the load applied to the narrow side, and to the wide side, and round and square tubing, and an I beam, and a channel.
2" x 2" aluminum channel open to bottom
1/8" wall
1000 lbf uniform load
2.674 lbm
20318 psi max stress - Gee, why is that so much higher than the others?
.243 in max deflection
Name:	Channel-Open Down-def.jpg
ID:	6658  Click image for larger version
Name:	Channel-Open Down-stress.jpg
Mark
NEED: carbon fiber/kevlar/composite I-beam Gabe15 General Forum 2 10-01-2008 08:44
Bending Metal Jeremiah Johnson FIRST Tech Challenge 2 01-05-2006 01:15
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
bending bumpers CharlieWilken Technical Discussion 3 19-01-2006 10:02
bending parts foobert FIRST Tech Challenge 4 15-01-2006 13:17
