#10
Re: pic: Dual FisherPrice Gearbox
I assume you'll be cheesholing the gears, too? I mean, if you're fretting over bearings vs. bushings, I can only think that you're planning to do that, but didn't see it in your CAD work.
Not knowing your end application, would it be reasonable to ask if a worm gear might be a suitable design. You can buy worm gears in ratios up to 80:1 off the shelf and they tend to lock in position... a handy thing if this is for an arm or lift. Just a couple of thoughts... otherwise it looks great and you're getting some good advice on this thread! Jason |
| White Paper Discuss: Dual-motor, dual-speed gearbox | CD47-Bot | Extra Discussion | 8 | 05-04-2004 19:24 |
| Gearbox/ Dual Motor Setup | matt111 | Technical Discussion | 8 | 02-12-2003 09:43 |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 07-10-2003 15:04 |
| Multi Speed Dual Motor Gearbox | tenfour | General Forum | 14 | 08-09-2003 13:09 |
