| Thread Tools |
Rating:
Display Modes |
#16
Re: pic: 2009 robot idea
Looks good, nice and simple like it should be. I'd prefer just using dead axles in this particular set up for the end wheels, it would probably cheaper and easier to build. Either way, it looks like a very solid drivetrain.
Does anybody else notice the trend lately of putting the wheels between two plates held together with standoffs? I may be imagining, but there seem to be a lot of teams using this method recently... |
#17
I agree there has been a trend for this and we are guilty of it as well. I have tried many different drivetrains and this method (2 plates with standoffs) really seems to be the best one I have done. It is particularly good if you are sponsored by or have access to sheetmetal stuff aka Laser or waterjet because the entire frame for the drivetrain can be knocked out in a couple hours. Also it allows for really quick assembly and wheel changes as well as it is super easy to incorporate the transmission into the frame, thus reducing weight.
#18
I however disagree with your comments on weight and strength. The shape of 80/20 gives it superior stiffness to 1x1 and the weight is comparable to 1x1x1/8 tube if you actually look at weight per foot among other things. |
#19
so, i have been trying to design a lighter chassis than this years robot (at ~60 lbs) and i came up with this:
![]() by my calculations, it will move at 14.82 ft/sec high gear and 5.79 ft/sec low gear. i have also figured the weight to at at around 45 lbs. and just for future reference, 1x2 8020 weighs about .98 lbs/ft, and 1x2x.125 aluminum weighs about .88 lbs/ft. not much of a difference when the strength is taken into account. Last edited by pacoliketaco : 06-26-2008 at 10:14 PM. |
#20
Great job here. The concept looks very similar to the 25 drive adaptation that 103 has been running with good success for a couple years. They swear by the 8020 ease of prototyping and retrofitting. You may want to get in touch with them to bounce ideas around.
-wayne |
#21
With a chassis that is less than 60 pounds, a majority of the weight is going above the chassis, raising the center of gravity to a less desirable place. Our center of gravity in 2007 was seriously at the bottom of our chassis. Teams would really have to try to get us to tip over. That chassis was probably close to 80 pounds. ![]() |
#24
One thing - I always like keep things simple and easy with few parts.
Have you considered just using aluminum C-channel (or even square tubing) for the left and right areas where the wheels are? A hole saw can make quick weight savings holes, and you don't need the fasteners, the machining, etc. It's stronger, lighter, and easier to make. Just a suggestion. |
#25
This is VERY similar to my team's last two drive trains. This kind of system is very adjustable and easy to build. It's worked great for us these last two years. 2007: ![]() 2008: ![]() Some things to consider: 5.79 fps is probably a little two slow. We ran low gear at about his speed this year and it was useless. The slowest I would go is 7 fps. You could save more weight with #25 chain. This system makes chain tensioning a breeze, and you could easily implement #25. We used #25 this year and never lost a chain. I'm curious as to why you put the axles on the center line of the extrusion. It would be a lot easier to put the pillow blocks on the top or bottom. You could save a lot of machining, and replace the 1020 with 1010. Altogether great work though. Are you gonna build a prototype? |
#27
A note on the weight.... Remember that this year's control system will weigh significantly (3-8 lbs., if I recall correctly (someone correct me)) more than in previous years. It also will require quite a bit more (continuous) space than in previous years.
Love the design. We need an overhaul on our concept of the idea of a 'working drivetrain' (currently my team is having trouble with that concept), and this is a great place for us to start! Jacob |
#28
thanks for all comments/suggestions. i guess i could change the sprocket on the two wheels powered directly from the transmission to something smaller. the main reason that i wanted to use 1020 and mount the axles in the center was for strength. the past three years, we had a very similar drivetrain, which i felt was excessive, but then again, it was very robust. the reason i want a light drivetrain, is that in the past three years my team had been in FRC, we havent had a complicated robot. our other systems end up to be too heavy, and we have to make accommodations by making simpler mechanisms. this year i dont want to have to worry about weight, and starting off 10+ lbs lighter will help.
2008: ![]() 2007: ![]() i wanted to make something that was only one level of 8020, to reduce weight. in the past i noticed that a single 1010 rectangle bends too much, so i decided to use 1020. using only 6in wheels, by putting them on either the top or bottom, there was 7/16" of clearance (too little) or 3.5" (too much) about the weight of chain, #35 chain weighs only .21875 lbs/ft, and with 9.5 feet of chain that is only 2.078 lbs. switching to #25 chain, which weighs .085 lbs/ft, would save 1.27 pounds, which isnt much for all of the added trouble. the purpose of all of my designing is prep for next year, as our team doesnt have the time/materials to build a chassis during the summer. just to see that your team seems to have built the same thing that i wanted to make, shows that i am headed in a good direction. as to how i make the chains in autodesk, i just use the KOP download, and modify each link a little bit. i added a VERY small rectangle in the center of them, in order for an angle constraint to hold them together. or you can ground one end of a set of links, and simply drag the other end away from it, until it is straight. once you do this, you have length of straight pieces of chain, but you still need the curves. to do this, i find the distance from the center of each sprocket to each other, and make a new assembly to work out of. i then add in the links one by one, making them fit around the sprocket. then i add in the straight pieces, and put the whole assembly on the finished robot. its a lot of work, but it looks awesome =] Last edited by pacoliketaco : 07-07-2008 at 06:16 PM. |
| pic: 2009 Control System, Mounted | Billfred | FRC Control System | 23 | 05-01-2008 07:02 PM |
| pic: 2009 Distribution Block | Billfred | FRC Control System | 16 | 04-22-2008 05:16 PM |
| Idea to elevate robot. | Gboehm | Pneumatics | 4 | 01-14-2007 03:15 PM |
| Real cool Robot Idea | Marcel | Rules/Strategy | 17 | 02-27-2006 08:21 PM |
| Robot competition business idea | Swampdude | General Forum | 6 | 03-16-2005 04:05 PM |
