Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
Unread 06-06-2008, 09:42
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
Re: pic: 2016 Steering module
Thanks guys... This steering is following the concept of the ackerman steering to answer the first question. It was initially design used a chain and sprocket but that provided too much slip and the pot didnt like it. So we switched to a Stackerbox. The turning radius is biased towards left as you can guess from competition. The robot also has a "code" differential to shift power after our steering wheel move past 20 degrees of steer.
Monty was all rookie drivers and stuff so they were still getting used to the bot, not our best performance but it was fun.
We will be at Brunswick Eruption and Ramp Riot later this year.
The best that robot has done is 11 laps and 5 line in autonomous. This was done in Chesapeake. The last match we were in on Friday evening.
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
pic: Team 11 and 2016 Winning Alliance at Chesapeake ks_mumupsi Extra Discussion 6 08-06-2008 00:33
pic: Team 2016 Robot ks_mumupsi Robot Showcase 0 19-02-2008 22:57
pic: 2016 at NJ Regional pstrapp Extra Discussion 3 03-03-2007 19:21
pic: Team 2016 Rookie Robot Sean Marks Extra Discussion 7 28-02-2007 17:35
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
