Go to Post Gracious Professionalism at its finest - Competing like CRAZY on the field, then working together like professionals off the field to make these events the best they can be for everyone involved. - Stu Bloom [more]
Unread 12-06-2008, 06:37
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: pic: Madtown Robotics Future Frame Proto 1
Personally I dont like the direct connection between the motor and trans to the wheels cause if you get hit hard enough you could bend the drive shaft coming off of the trans. Or am I just seeing it wrong and it's chain/belt driven.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 12-06-2008, 08:41
artdutra04's Avatar
VEX Robotics Engineer
You should look for a stronger way to beef up that frame; especially running along the length of the robot. I would suggest making the ribs along the corners of the box extrusion have at least a .625 or .75 lip.
Also, what kind of CNC machine would this be produced on? If it's just a regular milling machine, you'd honestly be staring at the machine for days to machine those side rails. I've seen even simple triangulation patterns take an hour.
A much better solution would be to reduce the number of pockets in half by using larger, triangular-shaped pockets. This would be harder, better, faster, stronger, and a lot easier to machine. (Time is money during the build season).
(Remember, a 150 pound force on a robot frame would be the equivalent of static loading if the robot were to push against a wall. During impacts, the force skyrockets in short bursts, which could easily exceed the 150 or 300 pound load test and bend your frame.)
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-06-2008, 11:43
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
Another consideration is that all of your cool designs on the machining will not be visible due to bumper.
If it was me I would simplify the trusses to a triangular pattern to speed up machining and make it stronger.
Mentor 2415
Unread 12-06-2008, 13:53
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
It is Chain driven and the machining for this proto will be done over summer as a CNC test and we will make another and i do need to strengthen it up a bit =)
R.C.
MadTown Robotics Team 1323
Unread 12-06-2008, 16:23
Very, very true. If you have taken physics you can do some approximations (they won't be very accurate) of the forces involved if two robots impact. Even though inaccurate, you'll be able to see that some very high forces can be applied in impacts.
Unread 12-06-2008, 17:52
R.C.'s Avatar
Our 2006 robot came back from Nationals and the 80/20 material was all bent up and the bot looked as if it had fallen off a roof top or something
R.C.
Unread 12-06-2008, 18:19
The scale just doesn't look right at all to me..... If the sides are 4x4, those motors look much smaller than small CIMs
Unread 12-06-2008, 18:33
R.C.'s Avatar
i got the drawing for the cims and the gearbox from a team at a regional, it is a dewalt setup.
R.C.
Unread 12-06-2008, 20:21
Hmmm.... I am 100% sure that those aren't CIMs w/ dewalt xrp gearboxes.
I don't know for sure, but I think those might be older drill motors from the KOP a long time ago.
I would go with Hachiban's recommendation and download from firstcadlibrary.
Unread 12-06-2008, 20:46
EricH EricH is offline
I'm with Adam on this. Those are 100% not CIMs, definitely not DeWalts either. They sure look like they could be the old drills, or maybe FPs. Odd mounting method, though it would make sense if you were going for cantilever (which you don't want here).
Unread 12-06-2008, 21:20
R.C.'s Avatar
For the wheels I meant http://www.omniwheel.com/cgi-bin/plu...de=Transwheel4 I'll ask team 418, thanks.
R.C.
Unread 12-06-2008, 20:12
run the trap!!!
Team Role: Human Player
I'm almost certian those aren't CIMs you're using. Try downloading the CIMs from the FIRST CAD Library and seeing how they compare...
This would be harder, better, faster, stronger...
I see you have learned much from Daft Punk
-Philip J. Fry
R.C.'s Avatar
If you're sure i'll do it, do you know of anywhere to get the dewalt gearboxes and the cims and 4 inch double set omni's. That would help me out a lot.
Thanks,
rc
R.C.
Unread 12-06-2008, 20:31
Thanks,
rc
I don't know where to download a model of the dewalt xrp gearbox, but 418 has been posting a lot of screenshots of them; ask them for the model.
As for the cims, go to www.firstcadlibrary.com under the motors section.
For the 4" omni wheels, I don't know anyone who sells them. You may be able to look at the 6" ones on AndyMark.biz and try to design a 4" version that uses the same rollers. Then make a hub to bolt two together.
Unread 12-06-2008, 20:41
run the trap!!!
He's refering to the Kornylak wheels, which are assembled the same way as the larger AM ones.
I've never bothered to make a detailed model of them. No point really... But all the specs can be found here.
-Philip J. Fry
pic: MadTown 1323 Robot Mast Shot Robo_Coyote Extra Discussion 7 06-02-2007 21:58
pic: Screenshot of Madtown Robotics Team 1323 Website. Hefner Extra Discussion 1 02-02-2007 21:18
Team 135 proto 1 CarpeDiem Robot Showcase 2 23-01-2006 21:26
pic: Team 121 Arm Proto Rob Extra Discussion 6 20-01-2005 23:01
Question About the Dashboard Proto. burNeD Programming 2 06-04-2004 13:09
