Re: pic: 968's 2006 practice bot chassis
I agree that this is a very good drive base that has really become the signature for many westcoast teams. But I still wouldn't build one for any of my bots, still don't see any point of exposing my wheels like that... (I know because I saw my team knock two of 254's wheels off in 2005)
What's that aluminum on the back for?
It's a roller that helps to keep the chassis from riding up onto balls.
Thanks.
Did you guys also have another piece to this? I see nuts that look like they're for an expansion. |
http://www.chiefdelphi.com/media/photos/23983 |
Eh, the shiny wheels are protected (heh, and covered up) by bumpers nowadays. If I remember correctly, there were no bumpers in 2005. It's still a great solid drive system.
I have to admit I can't figure out how to elegantly mount an AM super shifter to it, but I figure there's still plenty of time to work it out. |
During the design phase it appeared to be more weight to put bearing blocks for direct drive than it was to run more flat AM sprockets & chain, so I went with the 2-chained approach with tensioners directly mounted to the transmission (another bad idea). In hindsight, complexity of maintaining the chain system was what hurt us most this year, so it would have been much more simple to directly drive the middle wheel. We saw 254 & 233's bots in Vegas '07, and saw the simplicity of direct-drive on the middle wheel yet we didn't heed the reasons why. Coulda-shoulda-woulda's aside, maybe it's better we made our mistakes ourselves? The good news is, we didn't modify our SS's so now we {should} be able to use them again next year if the rules don't change. Now if we could only figure out where this little plastic washer goes on the SS that appeared out of nowhere on our table... |
#10
#11
i could never understand how the wheels stay on. could someone please explain this to me
#12
You can see this here , sort of. There's a groove in the shaft outside the sprocket. The snap ring expands to fit over the shaft, and then contracts when it is seated in the groove, and then keeps the wheels/sprockets from sliding off. |
#13
For some reason I can't edit my post. Here's the right link
#14
I believe that the sprocket is on the other side. It's a live-axle setup, so the sprocket is attached to the axle via keyway or hex, probably with a setscrew to keep it from sliding sideways.
| pic: THINK PINK 2k8 Practice-Bot | Gabe Salas Jr. | Extra Discussion | 4 | 20-02-2008 14:04 |
| pic: Beach Cities Robotics Demonstration & Practice Bot | akeisic | Extra Discussion | 6 | 05-10-2007 11:45 |
| pic: Team XBot Mecanum Practice Chassis | Fred Sayre | Technical Discussion | 28 | 22-11-2006 09:21 |
| pic: Practice Mecanum Chassis | Madison | Extra Discussion | 39 | 10-09-2006 20:17 |
| pic: It's a Monster for sure - Team 968's practice robot | Travis Covington | Robot Showcase | 14 | 22-03-2006 03:01 |
