Go to Post Let's sheathe the pitchforks and douse the torches for another two months, shall we? - Taylor [more]
Unread 13-06-2008, 13:22
CraigHickman
Re: pic: 968's 2006 practice bot chassis
Eh, the shiny wheels are protected (heh, and covered up) by bumpers nowadays. If I remember correctly, there were no bumpers in 2005. It's still a great solid drive system.
I have to admit I can't figure out how to elegantly mount an AM super shifter to it, but I figure there's still plenty of time to work it out.
Mounting a SS should be pretty "simple." Just make your own symmetrical side plates, assemble with standoffs, and have two holes designed in that are co linear with the output shaft of the center wheel. Those two holes allow the gearbox to bolt to the chassis member.
Unread 13-06-2008, 18:09
If you line up your cross members right, you can bolt on the SS's without any modification to them (besides longer bolts). 973 did that this year as we didn't have the resources to make our own gearbox plates. I'll take pictures when I can.
Unread 16-06-2008, 10:30
We did something similar this year with the SS's. We used an exactly dimensioned (with 1/16" tolerance) wooden block with manually CNC'ed holes to represent the SS to get the exact spacing correct while welding. The SS was positioned above the inside frame rail on either side. However, the output shaft wasn't inlined with the middle wheel.
During the design phase it appeared to be more weight to put bearing blocks for direct drive than it was to run more flat AM sprockets & chain, so I went with the 2-chained approach with tensioners directly mounted to the transmission (another bad idea). In hindsight, complexity of maintaining the chain system was what hurt us most this year, so it would have been much more simple to directly drive the middle wheel. We saw 254 & 233's bots in Vegas '07, and saw the simplicity of direct-drive on the middle wheel yet we didn't heed the reasons why. Coulda-shoulda-woulda's aside, maybe it's better we made our mistakes ourselves?
The good news is, we didn't modify our SS's so now we {should} be able to use them again next year if the rules don't change. Now if we could only figure out where this little plastic washer goes on the SS that appeared out of nowhere on our table...
GitHub
Unread 16-06-2008, 21:25
Pic 1
Pic 2
Pic 3
Unread 04-07-2008, 22:20
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
i could never understand how the wheels stay on. could someone please explain this to me
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 04-07-2008, 22:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We use snap rings to hold the wheels on.
You can see this here , sort of. There's a groove in the shaft outside the sprocket. The snap ring expands to fit over the shaft, and then contracts when it is seated in the groove, and then keeps the wheels/sprockets from sliding off.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-07-2008, 01:17
Cory's Avatar
AKA: Cory McBride
For some reason I can't edit my post. Here's the right link
2001-2004: Team 100
Unread 07-07-2008, 00:50
team2061's Avatar
Gilberto Gonzalez
but how is the wheel attached on the other side
Unread 07-07-2008, 00:59
EricH EricH is offline
I believe that the sprocket is on the other side. It's a live-axle setup, so the sprocket is attached to the axle via keyway or hex, probably with a setscrew to keep it from sliding sideways.
Unread 07-07-2008, 01:24
Cory's Avatar
AKA: Cory McBride
Exactly the same way. Both sides have hexes (that screenshot is of the 05 bot, and it used woodruff keys), and both sides have a snap ring groove in the shaft to retain the sprocket/wheel axially. They butt up against a shoulder in the shaft where the hex ends.
2001-2004: Team 100
Unread 07-07-2008, 15:59
team2061's Avatar
Gilberto Gonzalez
oh ok thanks now i understand
pic: THINK PINK 2k8 Practice-Bot Gabe Salas Jr. Extra Discussion 4 20-02-2008 14:04
pic: Beach Cities Robotics Demonstration & Practice Bot akeisic Extra Discussion 6 05-10-2007 11:45
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 22-11-2006 09:21
pic: Practice Mecanum Chassis Madison Extra Discussion 39 10-09-2006 20:17
pic: It's a Monster for sure - Team 968's practice robot Travis Covington Robot Showcase 14 22-03-2006 03:01
