Go to Post - Just because you can buy 50 giant pixie stix with your roommates Sam's club membership does not mean you should eat them all at once. - Not2B [more]
Unread 13-06-2008, 18:09
Re: pic: 968's 2006 practice bot chassis
Originally Posted by CraigHickman View Post
Mounting a SS should be pretty "simple." Just make your own symmetrical side plates, assemble with standoffs, and have two holes designed in that are co linear with the output shaft of the center wheel. Those two holes allow the gearbox to bolt to the chassis member.
If you line up your cross members right, you can bolt on the SS's without any modification to them (besides longer bolts). 973 did that this year as we didn't have the resources to make our own gearbox plates. I'll take pictures when I can.
Unread 16-06-2008, 10:30
We did something similar this year with the SS's. We used an exactly dimensioned (with 1/16" tolerance) wooden block with manually CNC'ed holes to represent the SS to get the exact spacing correct while welding. The SS was positioned above the inside frame rail on either side. However, the output shaft wasn't inlined with the middle wheel.
During the design phase it appeared to be more weight to put bearing blocks for direct drive than it was to run more flat AM sprockets & chain, so I went with the 2-chained approach with tensioners directly mounted to the transmission (another bad idea). In hindsight, complexity of maintaining the chain system was what hurt us most this year, so it would have been much more simple to directly drive the middle wheel. We saw 254 & 233's bots in Vegas '07, and saw the simplicity of direct-drive on the middle wheel yet we didn't heed the reasons why. Coulda-shoulda-woulda's aside, maybe it's better we made our mistakes ourselves?
The good news is, we didn't modify our SS's so now we {should} be able to use them again next year if the rules don't change. Now if we could only figure out where this little plastic washer goes on the SS that appeared out of nowhere on our table...
GitHub
Unread 16-06-2008, 21:25
Pic 1
Pic 2
Pic 3
pic: THINK PINK 2k8 Practice-Bot Gabe Salas Jr. Extra Discussion 4 20-02-2008 14:04
pic: Beach Cities Robotics Demonstration & Practice Bot akeisic Extra Discussion 6 05-10-2007 11:45
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 22-11-2006 09:21
pic: Practice Mecanum Chassis Madison Extra Discussion 39 10-09-2006 20:17
pic: It's a Monster for sure - Team 968's practice robot Travis Covington Robot Showcase 14 22-03-2006 03:01
