Go to Post I think all we need now is Jenny Craig for Robots. - ErichKeane [more]
Unread 03-06-2008, 19:28
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
pic: Latest Drivetain Assemby Render
Unread 03-06-2008, 19:34
run the trap!!!
Team Role: Human Player
Re: pic: Latest Drivetain Assemby Render
If you decide to do one of these kinds of designs, I suggest you think seriously about how to mount the bumpers.
We had a similar cantilevered system last year and it worked great. But over the course of three competitions the bumper mounts got kinda bent and the bumpers started rubbing on the wheels.
We had to periodically pry the bumpers away from the wheels to keep it running smooth.
-Philip J. Fry
Unread 03-06-2008, 20:22
CraigHickman
Looks really nice, but it seems to be missing something. How exactly do you plan on tensioning the chain? The bearing blocks are there, but there doesn't appear to be a system for pulling them.
Looking good!
Unread 03-06-2008, 20:23
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
Wow, looks pretty good.
What does the weight analysis say (if it gives you anything of worth)?
Unread 03-06-2008, 21:21
Spark The Ancient
HA HA! that is for me to know and you to find out! the bearing blocks do not move my friend!
sorry I'm kind of exited about this design
in the neighborhood of 25 -30 lbs for everything including motors, sprockets etc.
Unread 03-06-2008, 22:22
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
hmmm are the slotted holes on the motor mount part of it?
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 12-06-2008, 02:57
Spark The Ancient
a very important part.
Unread 12-06-2008, 06:42
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Just a quick question, why did you go with 4 motors all in different trans? How strong will it be, I mean I think making a drive pod around the wheels would make it so much stronger
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 12-06-2008, 16:25
Spark The Ancient
simplicity, serviceability, and weight. As it turns out, my dual cim gearbox, CIMs and all will weigh more than two single CIM gearboxes, negating the advantage of such a component. this setup allows the use of less chain, and fewer parts in total. It also has redundancy in case one gearbox or motor or speed controller fails, the robot will still be able to move. also, the modular gearboxes can be swapped out quickly, allowing repairs to be made to the faulty module while the spare takes its place.
this design only uses 2 loops of #25 chain per side, both of which are easily tensioned, so weight is saved in that respect, as well and simplifying the number of sprockets needed to transmit power to all 6 wheels.
Unread 13-06-2008, 20:19
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Well, the advantage isn't completely negated. First of all, if you put two CIMs through one transmission you can usually make it so that you have less total gear/sprocket meshes and therefore less efficiency losses that way--which although small, start to stack up, especially with planetary transmissions. Plus, in shifting transmissions, it can help reduce the number of actuations required to shift (for example, two servos or pistons instead of four.) In that case, it could possibly still be a weight savings in terms of the overall system. But the way you're doing it could be better from a weight distribution perspective, too.
All that said, you're a total CAD champion in my book. Seriously, great work, really professional looking.
Unread 16-06-2008, 17:11
run the trap!!!
Hey, just a quick question about solidworks (you obviously seem to know a lot about it)
I got the free student package in the mail and it says on the back that it includes photoworks - but I can't seem to find it, or its toolbar. Do I have to enable it or something?
I'd like to try rendering stuff
-Philip J. Fry
Unread 16-06-2008, 17:20
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Check under Tools>Add-Ins
That dialog box should give you the option to turn it on for just that session or at startup.
--Madison--
...down at the Ozdust!
Unread 16-06-2008, 17:23
NickE's Avatar
NickE NickE is offline
_
Yes, you do have to enable photoworks, but its quick and easy.
  1. While in SolidWorks, go to the tools menu, and click Add-ins.
  2. Click the checkbox next to photoworks (and if you want it to run every time you run solidworks, click the checkbox on the right as well)
This will enable:
  • A new tab in the left column with material and environment options and such
  • A tab in the right browser with info about different materials
  • The PhotoWorks toolbar can now be shown by clicking on a blank space on the existing toolbar and selecting photoworks.
You can just play around with it if you like, but I reccomend the tutorials that come with solidworks (Help Menu > Tutorials)
EDIT: M. Krass beat me to it.
pic: Team 401 - Render B ggoldman Extra Discussion 8 19-02-2007 08:41
pic: Jabba's latest creation Richard Wallace Extra Discussion 3 02-11-2006 14:43
pic: Cooney Quest Render 1 CD47-Bot Extra Discussion 12 21-02-2004 10:52
pic: 1083 Render CD47-Bot Robot Showcase 9 19-02-2004 19:00
