Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 17-06-2008, 17:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Linear bearing rails: the Cheesy RAWC way
Originally Posted by billbo911 View Post
Maybe I'm missing something. Where can I "look at 254's lifter " . Are there any close up pictures posted?
From the CAD, I can see how it is restrained in two dimensions, but not the third.
This was the little demo we had set up in our pit in Atlanta, that allowed people to play with it. It's not representative of the actual setup.
The outside is a plain 1x2 that makes a U frame, with the bottom being solidly attached to the robot base, and the top the open portion. The top is held at the correct width by a spanner that goes across the two beams. You can see this in pictures of our robot--it's the piece the pulley/flag holder/spring mounts to. The bearings then mount as you see here, top and bottom.
The inside is a rectangle made of channel on the left and right sides, and 1"x2" on the tops and bottoms. it rides inside the bearings, as shown.
2001-2004: Team 100
2006-Present: Team 254
pic: 294 Prototype Base frame rails Borisdamole Extra Discussion 6 17-09-2007 18:19
Looking for linear bearing solutions Mona Technical Discussion 6 18-01-2007 19:40
pic: Team 968 - RAWC - 2005 Robot Travis Covington Robot Showcase 22 01-03-2005 19:40
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
RAWC in the news? Greg Ross General Forum 9 07-09-2004 23:40
