Go to Post By the way why do all american's spell Colour wrong?!?!?!?!?!?!?!? - akoscielski3 [more]
Unread 06-22-2008, 01:12 AM
pic: Stackerbox Mecanum Prototype
Unread 06-22-2008, 01:17 AM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Stackerbox Mecanum Prototype
Nice concept, I like it! Strong, simple, and easy to maintain... everything you need in a drivetrain. I especially like the use of stackerboxes as transmissions; using only one gear reduction and only one chain reduction should make it nice and efficient.
I'm not sure about the rectangluar crossmembers though... cutting the holes may be a bit challenging. Have you considered using round tubes at all? May make manufacturing easier.
Great design.
Unread 06-22-2008, 01:20 AM
MrForbes MrForbes is offline
or even just a channel across each end, so the frame can flex, since mecanums like "suspension".
I like the idea of using CIMs on stackers, who thought of that?
Unread 06-22-2008, 04:22 PM
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
My only input is that if you plan on using the Andy Mark 6" mecanums I would wait until the redesign is available next yea. 1675 had many problems with them this and Andy said that they are redesigning them to hopefully eliminate most of the problems seen this year.
Brown is the New Gold
Unread 06-22-2008, 08:44 PM
I agree with that. In Atlanta, Andy said they'd be redesigning to make the wheels stronger. I suggested a smaller size for some of our small class robots as well. Really hope to see those
Unread 06-22-2008, 08:56 PM
Carlee10's Avatar
Carlee10 Carlee10 is offline
Loves F.I.R.S.T.!!!!!!
FRC #1529 (CyberCards)
Carlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to beholdCarlee10 is a splendid one to behold
This might be a stupid question, but what type of metal is the frame made out of?
Attending- College!
Awards: BMR's 2008 Judges Award
"Courage is not the absence of fear, but rather the judgment that something else is more important than fear. The brave may not live forever, but the cautious do not live at all."- Movie quote
Unread 06-22-2008, 10:09 PM
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
-- To tension the chains, simply mount the chains and slide the transmissions.
[/cdm-description]
JK,
Without an active tensioner, my hunch is that the Stackerboxes will inevitably slide in the directions the chain is pulling them.
I'm guessing that you will need something actively pulling the sliding motors/stackerboxes toward each other to keep the correct tension on the chains; perhaps a spring or one of those gizmos that has an eye bolt on each end and has an oval you twist to move the bolts closer or farther apart.
Also, to avoid having the chain tension creating a moment that wants to twist the shaft the drive sprocket is on, a bracket that wraps around the sprocket and supports both ends of the shafts could be what is at each end of a tensioning system.
Blake
Unread 06-22-2008, 10:12 PM
The hardware store guys call them "turnbuckles"
(I know you knew that....)
Unread 06-22-2008, 10:13 PM
EricH EricH is offline
JK,
Depends on attachment. I've never seen the tensioning method described fail. It's standard Kitbot tranny attachment. Not sure how Stackerboxes attach, but if it's similar, there should be no problem.
Unread 06-22-2008, 10:41 PM
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Thank You! - I spent 30 minutes trolling through the (not-so-useful) Lowes web site trying to find/remember that word and avoid having to embarass myself; and I failed
Turnbuckle, Turnbuckle, Turnbuckle, Turnbuckle, ...
Blake
Unread 06-22-2008, 11:01 PM
s_forbes's Avatar
Key word is depends... Our rookie year we used slots in the frame (for the wheel axle bolts) to act as our tensioners, but they always loosened up after several matches. I know this strategy has worked for other teams before, but there was something funny about that first robot of ours...
Also note that the kit bot has an aluminum bracket bolted to an aluminum frame; lots of frictional force! Lexan may not act the same way and might slip, but I don't know for sure. A turnbuckle may be a very good idea! (or one of those cam shaped tensioners, like on the 968/254/60 drive)
Unread 06-23-2008, 12:27 AM
That's part of your problem. I've always seen it with the trannies. 330 '05 had this, with KOP tranny (slots in base plate) attached to the frame with bolts going into slots in the frame.
Also, why would anyone use Lexan as the drive frame? (And don't tell me to see the 2007 design book--that team used a metal frame to support their drive.)
Unread 06-23-2008, 01:08 AM
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
I believe Team 20 used Stackerboxes for their Mecanum drive this year. It seemed to work out pretty good for them. I may be mistaken though.
Unread 06-23-2008, 03:05 AM
s_forbes's Avatar
I was referring to the lexan part of the stackerboxes, not the frame rails. (as for lexan in drivetrains, you could see 190's robot in 2006 if you want a really neat example )
Unread 06-23-2008, 03:18 AM
I usually wouldn't use a COTS turnbuckle to tension chain as it just seems big and unweildy..... But, if you got one that is about the length between the inner bolts (to the center of the robot) on one stackerbox and the inner on the other, and the eyelets were about the clearance size for a #10, you could tension both chain runs by pulling the gearboxes towards each other.
EDIT: on second thought, get a turnbuckle with plain threaded ends instead. Make a block with a threaded hole for that end on one face, and a clearance hole for a #10 on the perpendicular face (not vertical). Put that block on one of the inner #10s on each of the stackerboxes, and hook up the turnbuckle to them.
AndyMark Stackerbox AndyB Rumor Mill 31 03-18-2008 03:10 PM
Stackerbox in Inventor Sean Marks Inventor 2 02-14-2008 03:17 PM
pic: Mecanum Prototype 1 Doug G Extra Discussion 8 04-06-2007 09:34 PM
pic: 3rd mecanum prototype TheOtherGuy Extra Discussion 4 11-16-2006 12:55 AM
pic: 2nd mecanum prototype TheOtherGuy Extra Discussion 9 11-12-2006 11:51 PM
