Go to Post I then asked if I could use a flux capacitor for power, but that didn't go over too well, either (they did say I could use it for decorative purposes, though). - Kevin Watson [more]
Unread 23-06-2008, 17:20
Re: pic: Simple, Yet Effective Chassis
We usually
Keep in mind that next year's electronics may almost weigh the same, but the weight distributions will be more concentrated due to a more compact design. What we "usually" do for mounting these systems will have to at least be reconsidered next year.
As for the above oak/lexan debate, here's some data. The other mentors and I have always asked ourselves what the real benefit of lexan over other materials was, so I just did some research.
According to matweb a typical lexan sheet has a density of ~0.041 lb/in^3 whereas most solid oak hardwoods have a density of ~0.021 lb/in^3. The flex testing of lexan was done with 1/4" sheets and yielded ~65% flex resistance over with-the-grain testing of oak, yet for almost twice the weight of oak. Hence, for the application of mounting electronics I think it's safe to say that typical 1/8" thick lexan and typical 1/4" thick oak are about equal when considering "will it work".
GitHub
pic: 968 - These parts are nice and simple! Travis Covington Extra Discussion 1 31-01-2007 13:53
pic: simple omni vex bot colin340 FIRST Tech Challenge 15 05-05-2006 17:16
Effective Coaching Jeff Rodriguez Rules/Strategy 13 19-03-2006 16:13
Effective web ads Petey Website Design/Showcase 0 15-08-2004 20:17
Effective Fundraising Letters archiver 2000 1 23-06-2002 23:58
