Go to Post I am the Evil Empire of FIRST!!! - Andy Grady [more]
Unread 27-06-2008, 19:49
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Re: pic: Upcoming CAD Teaser
I you haven't used photoworks before I would suggest watching the tutorial first as with anything in SolidWorks. Setting the material in for the part does not affect the photoworks material and setting the photoworks material doesn't set the part material (for weight COG etc...). If photoworks is enables in the add ins then the non render color will be affected by setting the photoworks material. If it isn't added in then the color is set using the normal appearance settings. If you have already set the appearance settings then setting the photoworks material will change the non render color but will leave the density settings and the like alone.
Hope that answers your question.
"History doesn't repeat itself - at best it sometimes rhymes" --Mark Twain
Unread 28-06-2008, 20:50
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
Just FYI: I made my own purple candy paint texture, but I suggest using the "car paint" textures to come out with nice stuff like this. I also turn up the shininess of some of my parts, such as my wheels.
If you want, shoot me an email and I can give you the material data files that I use. I also turn up anti-aliasing, reflections, and a few other effects, as well as the contours to produce nice renders like this.
remember, in real life, there are no perfectly square edges, and most extrusions actually have a 1/32 fillet on their corners! those details make a difference in the renders. I turn the contours on to make my CAD more understandable.
Unread 14-07-2008, 14:47
Spark The Ancient
eh?
how bout this? :
Unread 14-07-2008, 15:14
NickE's Avatar
NickE NickE is offline
_
nice job on the pocketed tubing
that pattern looks a little familiar
on the gearbox though,
it looks nice and compact
just a few quick questions:
  • what's the weight on it?
  • what is the material for the sideplates?
  • how does it mount?
  • how does the chain tension?
  • will there be 2 identical gearboxes for the 2 stages of the arm, or will one be different than the other?
nice job!
Unread 14-07-2008, 19:43
Spark The Ancient
  • 2.54 lbs
  • POM Acetal Copolymer aka: Delrin
  • it bolts directly to the box aluminum, sorry you cant see the mount point.
  • the same way 233 did it, with the tensioned idler at the top.
  • the gearboxes for the two stages of the arm are not finished yet, this one serves a different purpose
BTW: that is the BaneBots 540 motor. i am using the fisher price for a different part of this design. the stall load on this gearbox is approximately 25 lbs, with a 24:1 ratio
pic: 229 CAD Teaser 1 Rob Colatutto Extra Discussion 4 01-02-2007 01:10
Upcoming Season Leon Machado IV FIRST-related Organizations 7 12-09-2004 23:29
pic: 111 Teaser (tiny teaser) CD47-Bot Robot Showcase 15 04-03-2003 00:49
Upcoming Robotics' Workshops Redhead Jokes Southern California Regional Robotics Forum 1 12-11-2002 02:26
The Upcoming Year archiver 2000 4 23-06-2002 22:06
