Re: pic: 968's 2006 practice bot chassis
i could never understand how the wheels stay on. could someone please explain this to me
You can see this here , sort of. There's a groove in the shaft outside the sprocket. The snap ring expands to fit over the shaft, and then contracts when it is seated in the groove, and then keeps the wheels/sprockets from sliding off. |
For some reason I can't edit my post. Here's the right link
I believe that the sprocket is on the other side. It's a live-axle setup, so the sprocket is attached to the axle via keyway or hex, probably with a setscrew to keep it from sliding sideways.
Exactly the same way. Both sides have hexes (that screenshot is of the 05 bot, and it used woodruff keys), and both sides have a snap ring groove in the shaft to retain the sprocket/wheel axially. They butt up against a shoulder in the shaft where the hex ends.
oh ok thanks now i understand
| pic: THINK PINK 2k8 Practice-Bot | Gabe Salas Jr. | Extra Discussion | 4 | 20-02-2008 14:04 |
| pic: Beach Cities Robotics Demonstration & Practice Bot | akeisic | Extra Discussion | 6 | 05-10-2007 11:45 |
| pic: Team XBot Mecanum Practice Chassis | Fred Sayre | Technical Discussion | 28 | 22-11-2006 09:21 |
| pic: Practice Mecanum Chassis | Madison | Extra Discussion | 39 | 10-09-2006 20:17 |
| pic: It's a Monster for sure - Team 968's practice robot | Travis Covington | Robot Showcase | 14 | 22-03-2006 03:01 |
