Go to Post I personally find the time I spend developing FIRST teams and FIRST as a whole the most fulfilling thing I have ever done in my life. - PayneTrain [more]
Unread 24-07-2008, 23:15
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
Re: pic: drive base idea
Originally Posted by cooker52 View Post
Dead Axles? Never heard of that before...
If it is going to be a two wheel drive, may I suggest you use omni wheels on the corner wheels. This will improve your maneuverability greatly and prevent that skip the robot has everytime you turn.
It's looking pretty good. When do you think you will be having more of it done?
Bearings are in the wheel and sprockets are mounted directly to the wheel. The shaft doesn't spin. Dead and live axels have their advantages. If you do dead axels right, you can just remove to bolts holding it in place and the shaft can just move out of the way, making wheel replacement very easy.
What 1519 has done in the past is cut vacuum tube and zip-tie it to the corner wheels. They still get a bit of forward traction, but it greatly reduces the side scrub.
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 114 drive base CAD CraigHickman Extra Discussion 4 15-12-2006 00:31
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 254 completed drive base CD47-Bot Robot Showcase 1 26-02-2004 16:34
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
