Go to Post It's over, done, let's move on and be positive. Next year maybe everything will be perfect. :cool: - Ed Sparks [more]
Unread 25-07-2008, 14:59
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: pic: drive base idea
Originally Posted by dbell View Post
Thanks to everyone for their comments.
Somehow the description didn't get posted when i uploaded the picture. What you see weighs 19 lbs. I haven't decided what gearboxes to use, but i have AM toughboxes or DeWalts in mind. The frame is 1x1x3/16 square tube, and will be welded.
Yes, Only the 2 center wheels are powered.
I was not planning on using 80-20 because it would make it heavier than i want this design to be.
The angle aluminum that supports the axles is 3/16 inch thick.
InfernoX14 explained dead axles.
Do you mean done in CAD, or built?
I will probably continue CAD of this design and similar ones until 2009. I don't know when i'll be 'done'.
To answer the comments about 6wd vs 2wd:
This drive base design was meant to be simple and light. Part of meeting this goal meant not powering the corner wheels.
For 3 out of the past 4 years, 1519 has used a 2wd drive, powering the center wheels only.
We have had good success with this design. The only drawback of this drive system is, like IKE points out, it cant climb ramps.
I like 6wd, but this design is meant to be the simple, light, stick-with-what-we-know design.
They are custom 6 inch aluminum wheels with roughtop or similar tread material.
They are 'poor mans omnis'. I'd like to get away from using them too, as are heavy.
Poor mans omnis are a lot cheaper than regular omni wheels, and they slide laterally very well, but not better than omnis.
Ryan, thanks for your advice about torquing the frame. Where would you recommend putting the round tube?
Comments are welcome
DB
I saw your request. I have go run some errands and then draw it up. Really, a few inches inside the frame will work. I'll try to autocad it up quickly.
EDIT: As promised, here is a drawing. Of course, you can move the tubes to wherever you want, but towards the ends makes it the strongest, however, having it on the very end may not be the best idea because your mechanism may not be able to work properly.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 114 drive base CAD CraigHickman Extra Discussion 4 15-12-2006 00:31
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 254 completed drive base CD47-Bot Robot Showcase 1 26-02-2004 16:34
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
