Go to Post A robot is replaced every season by the next robot, but a friend, team member, mentor, and memories will never be replaced. - Jverdon [more]
Unread 25-07-2008, 21:43
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: drive base idea
Originally Posted by dbell View Post
The frame is 1x1x3/16 square tube, and will be welded.
I was not planning on using 80-20 because it would make it heavier than i want this design to be.
The angle aluminum that supports the axles is 3/16 inch thick.
Just a little lesson here.
1 x1 x 1/8" aluminum tubing weighs 0.5132 lbs per foot
1x1 80/20 weighs .5097lbs per foot
so in this case your design weights more than with 80/20 now this doesn't take into account the hardware weight. Also 1x1x 3/16" is not a common size for tubing typically it comes in 1/16 or 1/8"
Greg Needel│www.robogreg.com
pic: DeWalt drive base dbell Extra Discussion 16 18-09-2007 17:10
pic: 114 drive base CAD CraigHickman Extra Discussion 4 15-12-2006 00:31
pic: 195 Drive Base Tom Bottiglieri Robot Showcase 24 16-02-2006 12:50
pic: 254 completed drive base CD47-Bot Robot Showcase 1 26-02-2004 16:34
pic: 1083 drive base CD47-Bot Robot Showcase 11 24-02-2004 14:04
